  • 11 Vote(s) - 3.36 Average
Another ME9.7 xprog Help!!!
Hello Guys,
Im a Newbie, Please help guys, Im working on a Merc GL450 2007mdl with
an ME9.7 ecu. problem is Ecu got fried/burned. I got a Used ECU with exactly the same part nos. what im trying to do is clone the damaged ecu and put it all in the used Ecu. I have Xprog, from reading around the forum i know this can be done by bdm connection. Please walk me through the steps i dont want to cause damage to the donor ecu. i have a few questions and I attached some pictures.
first: im following the Xprog bdm connection in the picture attached, im trying to get a reading but nada. I think this is because i need to connect a power source on the ecu being read, where should i connect this? and what voltage should it be? 12v?533
second:
in the xprog device selection am i correct to choose MPC5xx? for MPC564MZP68.
it also has a selection
MPC
configuration A
Configuration B
etc
which one do i choose?Fing20
thank you in advance
File Type: .jpg
Downloaded: 92 times
File Type: .jpg
Downloaded: 64 times
File Type: .jpg
Downloaded: 76 times
the board is pretty damaged. I think you'd be better served to remove the chip your trying to read.
I'm not familiar with the ecu but I think you need one of those soic 8 chips mostly that has the vin info stored. Then for full clone if you wanted exact copy the bigger chip middle top.
Again I don't know this board and cant really see in your pictures so I may be way off...
Hi i still need to know how to read the mcu of the me9.7 ecu correctly
in this case I would recommend you just swap chips.
I don't think it will be possible to read original ECU with the shape it's in
Have you tried reading the donor with the diagram you provided?
Thanks given by: EGYAUTO
#5
swap eeprom
Use KTAG diagrams. 10 BDM pads by baro sensor and 15-16=+12v and 2=Grnd(small connector). read MPC564 datasheet first.
Why waste your time ? Make donor ecu virgin and teach in with Stardiagnosis...
Thanks given by: familyman , EGYAUTO , narkeleptk , Ruperto
#8
(10-12-2017, 11:49 AM)Jan1980 Wrote: Why waste your time ? Make donor ecu virgin and teach in with Stardiagnosis...
+1
+1
Chevrolet Chevrolet Kalos Matiz 05H12 XPROG figani 4 59 59 minutes ago
Last Post: figani
Mercedes Benz Pinout Bosch ME9.7 Mercedes W211 vahid-miralizadeh 2 133 09-21-2018, 10:10 PM
Last Post: vahid-miralizadeh
  please i need virgin 95080 from me9.7 ml63 angolatech 3 144 09-21-2018, 07:55 PM
Last Post: angolatech
Mercedes Benz FILE FOR ME9.7 ML osmik 3 201 09-21-2018, 04:36 PM
Last Post: tpresser
  Xprog no dongle matej12 4 187 09-08-2018, 06:38 PM
Last Post: matej12
