81
Thanks Given: 125
Thanks Received: 245 (64 Posts)
293
60
09-21-2024, 01:16 AM
(This post was last modified: 09-21-2024, 01:37 AM by kecho.)
Hi!
I am working on an Astra H with PEPS. Car arrived not going into ignition on, just key icon flashing.
Managed to read the PIN, after resetting the CIM the car now wakes up, but the CIM programming fails.
CIM seems to be a 13250223 with M:90.57 software. Does this CIM needs to be replaced for a 93184343?
Managed to reset IPC, REC, UEC, PEPS, ECU... but no luck.
Now the PEPS doesn't want to learn the keys back, throws an 0x40 error.
PS: Have a Tech2 and a O/V VCI, if SPS programming is needed, I can give it a go.
281
Thanks Given: 22
Thanks Received: 443 (73 Posts)
140
i can program for you.
Please Leave Rep + Thank You if I helped you.
BMW programming + All key lost solution
Mercedes programming, AMG menu, CARPLAY
Range rover Topix + Pathfinder
Ford IDS, FJDS, FDRS original license, PATS login
GM +Opel online programming
Toyota
81
Thanks Given: 125
293
60
Tried doing an SPS programming today, but got error E4419: Unknown ECU software detected. Is any way around this?
670
Thanks Given: 224
Thanks Received: 1408 (399 Posts)
1,122
193
Can you provide VIN?
670
Thanks Given: 224
1,122
193
(09-22-2024, 02:51 AM)kecho Wrote: W0K0AHL0885063650, Vauxhall Astra VXR
Latest cal on https://tis2web.service.opel.com/tis2web/ is M:80.62 or M:82.49. Nothing for M:90.57
You definitely need CIM with some of this HW nums.
81
Thanks Given: 125
293
60
09-22-2024, 02:35 PM
(This post was last modified: 09-22-2024, 02:41 PM by kecho.)
Yeah, that is weird.
I have tried "programming" it with a Tech2 184, after being reset I can switch the ignition on, reset all the other modules and program, the live data on the CIM shows the environment data is invalid.
81
Thanks Given: 125
293
60
Old topic. Got this car running, a new fob was programmed and now it runs perfect.
