(10-24-2024, 12:27 AM)RSGuntha Wrote:Thanks for answer. I was read it KT200II it was full read. Ecu was replaced for new one with same result. I add you 2 softs. First is oryginal and second is with adblue, dpf, egr off. On both softs is same results black smoke and fuel smell from exhaust. I also recieved turbocharharger from regeneration but same result.(10-19-2024, 03:30 AM)JohnTdi Wrote: Car come to me with damaged dpf. First I removed dpf and egr (good ecu solution) to make some drive test. With removed dpf and blanked egr it was no difference with that black smoke so I back to ori file. Now car have removed dpf but I want bring it back. Anyway before I buy new DPF i must fix problem with black smoke to dont destroy new dpf :/
I know that delco e98 its difficult ecu. Is it possible that ecu adjust fuel stroke map to desired pressure sensor values not to MAP readings ?
Which Tool you Read and Write Delco ? Its Possible ECU is defekt.
Much Tuning Tools Read/Write this ECU not Correct.
The Best Tool for this is IO Terminal or MD Flasher.
Read File and Post it here.
Regards
Günther
Astra K 1.6 cdti 110HP LVL engine boost pressure
11
10-27-2024, 08:14 PM
Your File is um 1KB to big and Checksum (End of the File Lost)....
So in File from Delco E98 is also Immo Data... In Original File is : W0VZM8EFXK1076643 Ist this Car FIN?
In your Tuningfile is Other FIN Inside: W0VBD8EF2K8075950 .... this is not Correct Matched with WINOLS... is a Bad File.
So in Attachment is your Original Repair File with Cheksum.
When you write this File with KT200, make Sure a Good Stabil Internet Connection and a Good Battery Charger.
If you have the opportunity... then write it with MD Flasher or IO Terminal..
It is possible that you have already activated the closure of the can signal.... If the file is written incorrectly again, the Delco E98 closes and is blocked... Then you have a stone in your car.
So please be careful.
Tuningfile is not for Free :-).
Regards
Günther
Regards
Günther
Thanks given by: JohnTdi
