chavez
Location OfflineJunior Member
10
Thanks Given: 23
Thanks Received: 41 (38 Posts)
139
37
I'm trying to fix Astra K 2018 with faulty Steering rack. Water got to the Power Steering unit. I tried to order a new one but even if customer would have the ridiculous amount of money the rack is unavailable. That is why I try to make it work with used one. I'm stuck at programming it because sps2 needs propper vin in the module. I try to use gm dps but I don't have the zip file for it. I'm looking for someone that can help. I have 20h left to use sps2.
105
Thanks Given: 105
Thanks Received: 390 (182 Posts)
409
If you tried programming it with sps2 then you have the files you need to create an archive for use with dps. Then you can put the vin in that you want in ecu info page, then program with dps.. Cannot say whether or not there is immo keys that have to be done as well though. I have not personally attempted on an 18, I have done a 2013 and 2014 equinox steering gear but yours is 4 years newer.
chavez
10
Thanks Given: 23
139
37
I know that sps data is needed to create the files but no experience how to do it.
Thanks Given: 28
Thanks Received: 13 (7 Posts)
48
10
Google VXUtility, this software will do the VIN change required.
281
Thanks Given: 22
Thanks Received: 443 (73 Posts)
140
PM me i willl install a software for you to change vin in all opel and GM cars
Please Leave Rep + Thank You if I helped you.
BMW programming + All key lost solution
Mercedes programming, AMG menu, CARPLAY
Range rover Topix + Pathfinder
Ford IDS, FJDS, FDRS original license, PATS login
GM +Opel online programming
Toyota
chavez
10
Thanks Given: 23
139
37
If anyone interested. What I have done is swap the EPS motor/module ONLY. VXUtility helped a lot with VIN. VIN change went with no issues. Straight forward and easy with that software and Openport. After that aligning steering angle sensor also worked BUT... here it gets tricky. After all that I can see the steering angle sensor working all the way from left to right, but if I go past 180degrees left and about 250degrees right I get C0460-5A and ESP light. The sensor works all the way to 540degrees with no issues. I'm clueless why. Maybe someone here have an idea? I think about trying SPS2 to fully program the module but my access expired and I don't want to pay for another 24h just based on guessing.
