Audi A3 eepron internal error
Hi
I have an Audi A3 /2009 with engine 1,9 tdi (BLS), with automatic gearbox.
The car functions well, but in engine control module i have an permanent error ;
EEPROM INTERNAL ERROR.
I opened the ecu, and i found some water sign, i have cleaned, but error still remained.
The ecu has sn: 03G 906 056 N
Bosch SN ; 0281 015 168
With kess, ecu id is :
HW:
SW: 1037395485
VIN nr.: õÔM˜Åœ–²#qy1$•w÷
SW ver.:
Spare:
Engine: R4 1,9L EDC
HW Ver.:
SW upg.: 03G906056N  3039
Installation:
I have read eeprom  with Galetto.
PLS CAN ANYBODY HELP ME WITH AN FULL BDM (OR WITH A BIN FROM EEPROM)
eeprom ori.rar
25
1.24 KB
Pls attach also flash and dtc error.
I can help you
Chiptuning DynoTested
File services - DPF/EGR/DTC Exc
PCR2.1 Full Clone - Edc17 Full clone
/t.me/Edc17tricore
You are very wrong with what you are doing. So I see that you will not be able to do anything. Mount the switchboard, pray and start ...
ListenHandshake
flash
ext flasf ori.rar
91
534.87 KB
It's probably because it's immo off, with the wrong chek sum.
I have the same error on a Golf 4 with immo off
[Image: 2e1vodh.jpg]
IF YOU ARE SENDING ME PM AND ASKING FOR PASSWORD WITHOUT TELLING ME WHERE THE LINK IS HERE, I WILL DELETE THE PM !!
Thanks given by: testariauto , KriyenKPp
(03-03-2019, 09:12 PM)Alexuko Wrote: You are very wrong with what you are doing. So I see that you will not be able to do anything. Mount the switchboard, pray and start ...
The car is running well. i want only to solve the eeprom problems
(03-03-2019, 09:17 PM)keyzex Wrote: It's probably because it's immo off, with the wrong chek sum.
I swich immo to on but the error still
Ecu is EDC 16U34
A3 2009 is edc17. That's why I gave you a warning
ListenHandshake
Usualy yes, but that car has edc 16u34...check the ecu nunmber. i wrote that in the first post
(03-04-2019, 01:18 AM)testariauto Wrote: Usualy yes, but that car has edc 16u34...check the ecu nunmber.
Thanks given by: AlexH
(03-04-2019, 12:50 AM)Alexuko Wrote: A3 2009 is edc17. That's why I gave you a warning
This is EDC16
[Image: 219ruj6.jpg]
06-12-2026, 04:01 PM
06-11-2026, 03:36 PM
06-09-2026, 12:25 AM
