  • 6 Vote(s) - 3.17 Average
Audi Q5 MMI Navigation American to EU
Hello to all.
Audi q5 2015
8R1035746H - mmi
HN+_US_AU3G_P0900
No navigation data at this time.
Need to change language in MMI from US to Russian. And need navigation Europe. (Ukraine, Poland, ect.) Already flashed EEPROM in unit.
I understand that now i need to flash unit and than install maps with DVD or SD Card.
I founded solution for navi 8R0...(change region in "green menu" and then update) but i am afraid that is not correct for me. And i dont have navigation discs. Please Help.
If you need more info - ask me.
Navi Data install on harddrive
http://www.audienthusiasts.com/Infotainm...hange.html
Thanks given by: ladadens
(05-31-2018, 02:32 PM)codieren Wrote: Navi Data install on harddrive
thx, but where i can find this SD update for my MMI?
Map is here:
http://mhhauto.com/Thread-MMI-3G-Map-201...pid1143722
Firmware for Audi A4-A5-Q5-Q7 HN+_EU 0942
https://mega.nz/#F!UlYT3LZa!o2vtCDPKxmm0axBDwhMAVg
Activator:
https://mega.nz/#!gxBRBQoB!O_nnO7mbjc1AW...fMWSn1ZIS4
If you like my post and it helped you, press Thanks or Reputation Fing32
Thanks given by: babitur
audienthusiasts.com/Infotainment_EEPROM.html
audi-club.ru/threads/russifikacija-mmi-3g.361146/page-3
drive2.ru/l/469276786488771473/
Update FW in USER DEFINED MODE
______________________________________
Looking for an employer from Canada or USA. I'm the diagnostician with the big experience and retrofitting Vag.
Please THANKS and REP if my post helped Nod
You need VCP Pro to read eeprom and change language, after that emergency update to flash firmware but not the latest version because update will fail.
Take the oldest version and after that update the latest, erase map and before update in green menu change the region for map because update will fail every time when you try.
(06-02-2018, 10:38 AM)atomantmk Wrote: You need VCP Pro to read eeprom and change language, after that emergency update to flash firmware but not the latest version because update will fail.
Changed EEPROM without VCP. With desoldering.
Changed region with
flashed HN+_EU_AU3G_K0942_3 through Engeneering menu (without emergency)
then installed maps 6.26.1 :: 8R0051884FC and keldo 6.26.1 (2018) activator
also with engeneering.
works perfect 049
Thanks given by: jagoda , Aldi
Yesterday, 03:36 AM
07-16-2019, 12:19 AM
Audi
07-13-2019, 05:17 PM
07-11-2019, 10:18 PM
07-11-2019, 02:33 PM
