  • 27 Vote(s) - 2.74 Average
Autocom CDP can-bus problems
Hey,
Just a few moments ago I tried my Autocom CDP pro clone with Delphi 2013.2 on a VW Golf mk6. Didn't connect to any ecu... Afaik all of them are accessible via can-bus. Should I change the can transceiver (tja1050) or should I bypass the relays and connect the transceiver directly to the OBD port?
The firmware was upgraded when I installed Delphi Trucks 2013.2 and the unit is communicating to the pc properly.
Yes, I had a problem. Replaced the chip tja1050 - a device established a connection via CAN.
If I helped you, click [Image: postbit_reputation.gif]
Thanks given by: p1gl3t
Hi
Some people solved the problem can bus?.
I have too
And ideá is welcome
Regards
I'm planning to bypass the relays and connect directly to the CAN-bus transceiver. If that doesn't work I would do as sa1973 said and replace the transceiver.
08-12-2019, 01:02 AM
08-07-2019, 10:45 AM
AA+MHH
07-24-2019, 10:09 PM
07-21-2019, 02:49 PM
06-27-2019, 12:51 PM
