Autotuner Faulty On Bench
Hi Guys,
Got an issue with a recently purchased autotuner. The person I brought it from must have known about this issue hence the reason he sold it.
It works via OBD ok but not bench. I tried a few ECU's and all I get is Initializing ecu then eventually ECU initialization failed. Tested ECU with another tool and works.
I have found the problem to be the power. I connected a multimeter to the spare power and earth cables. The power is not stable and fluctuating between 2-12v when selecting id or read.
I am using the genuine adapter which is giving out 12v ok. In fact used this adapter with the other tool and it worked too.
Can anyone point out any components I should check/change to fix this problem? What component regulates the voltage.
See attached pic and video of the issue...
[Image: PXL-20240107-140648052.jpg]
[Image: PXL-20240105-000134121.jpg]
Thank you
Power is normal , check your bench cable with ohm meter end to end every wire  , here is picture for pinout
BMW E70 AKL_CAS2 to CAS3 transfer_BDC_FEM_VAG_DELPHI DCM 6.2 3.7_IMMO TRANSFER_BCM2_ECU_VAG_TCU_ELV_calc sync data
SPRINTER_EZS REPAIR_ W906/7 Vmax Removal_AdBlue Rem Starts Reset_FBS4_Ecu_FDCT_Drive Authorization
Thanks given by: smurf786
Thanks for the suggestion all the wires pin out correctly and none are shorting between themselves. I have good ohm readings.
I'm sure the power is the issue. It should have 12v or it isn't going to power ECU?
When I tested with other tool when i ID or read it holds 12v and does not fluctuate until the read is complete then the power is dropped.
It have 5 years guarantee
It's outside of warranty. I just got the tool if I can repair it is worth it... I can solder components if anyone know which controls the voltage or would make the voltage fluctuate like this...
Thanks I will try and test for a short. The board does look ok though. Nothing obvious...
If you have a short , you will have 0v all the time, you have problem with can lines….this is normal impuls Pow supply because unit try to do boot but don’t have communication at  the yellow and green wires …
Thanks given by: legendz
(01-15-2024, 06:30 AM)Hola Wrote: , chicos.
Tengo un problema con un sintonizador automático que compré hace poco. La persona que se lo compró debe haber sabido de este problema, de ahí la razón por la que lo vendió.
Funciona bien a través de OBD, pero no de banco. Probé algunas ECU y todo lo que consigo es inicializar la ECU y, finalmente, la inicialización de la ECU falla. Probé la ECU con otra herramienta y funciona.
He descubierto que el problema es la alimentación. Conecté un multímetro a los cables de alimentación y tierra de repuesto. La alimentación no es estable y fluctúa entre 2 y 12 V al seleccionar id o read.
Estoy usando el adaptador original que proporciona 12 V correctamente. De hecho, utilicé este adaptador con la otra herramienta y también funcionó.
¿Alguien puede señalar algún componente que deba verificar o cambiar para solucionar este problema? ¿Qué componente regula el voltaje?
Vea la imagen y el video adjuntos del problema...
Gracias
hi, i have the same problem, solved your problem?
Hi guys, I've already solved the problem. If any of you have the same problem, write to me and I'll send you a photo of the components I replaced.
Thanks given by: autosys.ltd , autobirotula
Users browsing this thread: clandestino
