(Yesterday, 10:29 PM)Aleksey-MS Wrote:(Yesterday, 07:14 PM)haski1234 Wrote: BMW Road Map Europe East/West PREMIUM USB 2025-2
I instaled in my bmw x3 2011 I have problem with coordinates, everything else works why and how to fix?
The system needs to be calibrated (the most common cause)
After installing new maps, the CIC system needs time to synchronize the new map data with actual satellite signals and wheel speed sensors (ABS).
What to do: Simply drive 15–30 km in open terrain (preferably on a highway where the GPS signal is stable). The system will automatically calibrate itself, and the point on the map will “catch up” with your car.
(Yesterday, 08:31 PM)haski1234 Wrote:(Yesterday, 08:08 PM)Aleksey-MS Wrote:(Yesterday, 07:14 PM)haski1234 Wrote: BMW Road Map Europe East/West PREMIUM USB 2025-2
Hi. Send a photo with error.
No errors just gps late 5km.
Here are the most likely causes, listed in order of probability:
The GPS antenna (in the “fin” on the roof) has failed: This is the most common issue. Without satellite signals, the system calculates the route using wheel sensors and quickly accumulates an error (lag). The map update is just a coincidence. Check: Go to the hidden CIC service menu; if the number of satellites is “0,” the antenna needs to be replaced.
System failure / Loss of almanac: The device has frozen or is searching for satellites again. Solution: Reboot the system (hold the volume button for 30 seconds), then wait 15 minutes in an open area with the ignition on.
Maps installed incorrectly: Error reading from the USB drive. Solution: Reinstall the maps using a different, high-quality USB flash drive.
Ok, I will drive for a few days and see if it calibrates itself.
Before these maps, I had the 2021 maps installed and they worked normally. Since I installed the new maps, I have had a problem with the coordinates, or rather a GPS delay of several kilometers. So it is not a faulty GPS antenna.
If it does not start tracking the satellites correctly by itself after a few days, then I will perform a reset using the volume button.
I did not have any errors when copying the files to the USB drive or during the installation. Everything went smoothly, so I can rule out that possibility.
