  • 56 Vote(s) - 3.02 Average
BMW E90 320D cruise control retrofit.
Hello!
A customer want to make a Cruise control retrofit in his car. I know I have to change the swith behind the steering wheel. After can I make coding in DDE and dash with Ncs?
(05-08-2014, 08:06 PM)Botosjeti Wrote: Hello!
You need to add FA code to CAS and FRM after that the DSC and COMBI modules restore with NCS to default!
- BMW FULL kit Panasonic CFC2 with ICOM with latest SW -
- Mercedes FULL kit Panasonic CFC2 with C4 with latest SW -
- Autel 908Pro with 2 YEAR SUSCRIPTION AND SHIPPING FROM EU -
79 Prices by PM! 79
Thanks given by: Botosjeti
If you've ista-p just select retrofit cruise control and it will code everything.
If my answer was useful for you press [Image: postbit_reputation.gif]
Thanks given by: Botosjeti , Camaro9434
add $540 in VO, and coding in ExpertMode (NCS) DSC / KOMBY,
later... reset the angle sensor of the DSC
[Image: firma-Cat-288.jpg]
(05-09-2014, 01:17 AM)duckdonald Wrote: add $540 in VO, and coding in ExpertMode (NCS) DSC / KOMBY,
How can I add $540 to FA/VO?(I think this could be done with Ncs too)
What do you mean restore to default the DSC and KOMBI? Not just make CC Aktiv in DSC and KOMBI coding?
VO = NCS -> ad $540 -> FA_WRITE in CAS and FRM.
Read ECU Kombi -> backup file .trc ( for restore )
Read ECU DSC -> backup file .trc ( for restore )
Code in expertmode -> Kombi and DSC.
reset angle sensor in DSC modul.
Your first post should be here:
http://mhhauto.com/Forum-Introduce-Yourself
Please press the [Image: postbit_reputation.gif] and [Image: postbit_thx.gif] if my post helped you...
Does anybody know why i dont have an Cruise control indication with speed set on cluster ?
I do fittet cruise control on a e90 30D and coded all correctly. Cruise Control is working but i got no indication.
BY2006 with low cluster
check in Kombi :
TCM_ALIVE_MONITOR
aktiv
TEMPOMAT_SETZ_ANZ_DAUER
wert_02
BC_2_ENABLE
aktiv
BC_LIMIT_ENABLE
aktiv
Thanks given by: elitebook
08-14-2019, 10:31 PM
08-10-2019, 07:08 PM
08-09-2019, 07:30 PM
08-06-2019, 05:37 PM
