  • 12 Vote(s) - 2.42 Average
Berlingo II manual AC
i have on work Citroen BerlingoII 1.4 ECU MA7.4.5 MY2003 with non worked manual aircondition.
There was problem with wires between ECU and AC presure sensor.
Now when is all repaired, ECU show about 5,1 Bar presure, no faults, but AC not work, both fan speed work, in BSi i can in outputtest swith on compresor clutch. On evaporator is aboput 15°C.
In ECU readness is still AC not alowed and No request to AC.
Is 5,1Bar not enought? Have anyone idea where can be a problem that AC not work?
Thanks a lot for any advice and help
PedroX5
(05-01-2016, 10:40 PM)PedroX5 Wrote: Hi,
PedroX5
In the model you specified, the clutch is manual.
Simply connect a plug and give external power supply to clutch.
See if it will work or not.
5.4 Bar are enough to start the compressor I think but always we look for the quantity to be more accurate....
Best regards.
[Image: mhhsig.gif]
Thanks given by: PedroX5
5 bar is enough for activation, even if its pressure and no refrigerant.
If you can activate test the compressor clutch, then that must work ok.
There must be an activation or blocking reason in the circuit/ecu system?
Thanks for advices, yes i can swith manualy cluth on, its work. I think that bSI not recognice a information from ventilator and that way don´t send correct information to Engine ECU. I think that i find corrosions in BSI, but this look like new one, i will check it on working car.
Problem solved, fault was in wire between BSI and ventilator, concretely in poor contact on this wire, so one simply fault take so many hours...¨
PedroX5
