Thanks Given: 112
Thanks Received: 38 (32 Posts)
268
74
good evening
Friends of the forum, I need to do the dpf removal of nissan navara car.
I'm researching which ecu programmer (clone) would be best to work with Nissan cars with dense ecu.
I have no conditions to buy original, well say it will be my first attempt to remove dpf. If more services appear I buy an original ecu programmer.
I have been seeing here in the forum, Galleto v54 is not good for dense ecu?
I am in doubt about 3 ecu programmers.
1 Ktag
2 Piasini
3 Galleto
4 kess does not support dense ecu.
Some tips some tips piasini ... 4.1?
Thank you all
Upa-S, ZedFull, CK100, SKP-900, FVDI, OBDMAP, VVDIkey, Roudrill key CNC. Xpad Scanmatik pro2 Mdflash PCMflash.
22
Thanks Given: 108
Thanks Received: 120 (97 Posts)
503
70
Ktag read all tables,you can use that.
50
Thanks Given: 65
Thanks Received: 133 (106 Posts)
352
13
(12-06-2016, 01:21 AM)cenksertoz Wrote: Ktag read all tables,you can use that.
Original KESS supports Denso for Toyota, Nissan, Mitsubishi, Mazda.
If you need specific extended works on Denso ECUs, you need this IO Terminal (DSM) tool, which also works via OBD.
Professional file service for tuning, DPF/EGR/AdBlue/ etc.
|CARS|TRUCKS|TRACTORS|WATER TRANSPORT|
Leading chip tuning equipment from Flashtec, Alientech, IOTerminal, Dynomax Dyno @ best prices & conditions.
//Galingas chip tuning//
254
Thanks Given: 638
Thanks Received: 809 (415 Posts)
1,135
140
Hi Fernandowap
if need for petrol nissan hitachi ecu is good piasini 4.3 master
BR asto
X-Tool 2025updt.PCR2.1 EDC17-TCU V.A.G Immo OFF,
Alfa159 Key For Sale,BCM2 data and ELV repair,MQB Sync.Key,BCM2 Sync.Key,DCM6.2 Immo off,PPD1.x Immo OFF,Siemens EMS3120,3125,Valeo V40,42 Immo OFF,Hitachi ecu Nissan 2000-2010 Immo OFF
29
Thanks Given: 257
Thanks Received: 236 (129 Posts)
419
50
01-25-2017, 12:38 AM
(This post was last modified: 01-25-2017, 01:15 AM by Raints.)
Is it Eu clone Kess works on this type denso ecu via obd?
It just makes me feel good
Thanks Given: 274
Thanks Received: 31 (24 Posts)
211
38
BONSOIR can be for denso see the I / O Terminal with the option that goes with it? Good evening @+
I'm the one to try to help you I start then soyer comprehensible
nuz18t
Location OfflineJunior Member
Thanks Given: 71
Thanks Received: 9 (8 Posts)
52
10
I bougth piasini (clone) a year ago to do a opel 3.0 cdti denso and never manage to find pinout for that ecu, it never work via obd, i read the file with fgtech and couldnt write back the new file. End up posting ecu to my tuner and he writed it with ktag, so i would say ktag as best option for denso...
Nuz
50
Thanks Given: 65
352
13
(01-25-2017, 02:01 AM)nuz18t Wrote: I bougth piasini (clone) a year ago to do a opel 3.0 cdti denso and never manage to find pinout for that ecu, it never work via obd, i read the file with fgtech and couldnt write back the new file. End up posting ecu to my tuner and he writed it with ktag, so i would say ktag as best option for denso...
Nuz
Maybe KTAG is the best option, when "tuner" doesn't have any good and original tool...
