  • 4 Vote(s) - 2.75 Average
Bravo T-Jet 150PS
Hi
It is posible to make block self-adaptation value on this ecu Bosch ME 7.9.10, 0261201687.
Car works good, no DTC, short and long time fuel trimer is neer +/- 2%, but on morning start engine is difficult.
Ori MPC file in attachment.
Regards
Bravo ori.rar
File Type: .rar
Downloaded: 3 times
(10-11-2018, 02:01 PM)konop11138 Wrote: Hi
Regards
It's not fuel trim problem if they are +/- 10%. Look for different issue like spark plugs, coolant temp sensor, dirty injectors. You can make a log of the cold start with FES/Multiecuscan and post it here. Without logs nobody can help you as we're not a forecasters.
Beware with files from Mirnel. Car does not start or worse, engine damage. DO NOT pay as a friend
Volter thanks for your answear,
but mi qestion: is posible or not block self learning adaptation, this ecu have another autoadaptation corector, not only long and short fuel trimer like in this car with 120PS engine.
Maybe one of you has an eeprom 95080 dump to this ecu?
  Fiat Bravo 1.6 JTD Original File needed Lunacy 4 73 10-05-2018, 10:58 PM
Last Post: Lunacy
Fiat Fiat Bravo 2009 1.6 mjet 105hp ori NenoRi 1 105 09-20-2018, 05:08 PM
Last Post: Mirnel
  JET SKI Tune Inquiry Yamaha waverunner 1800cc FZR pambos100 7 225 09-07-2018, 12:49 PM
Last Post: Audis
  Looking for ori file BRAVO 2.0 MJET drakexpl 10 216 08-29-2018, 03:40 PM
Last Post: drakexpl
Alfa T-jet damos file for 1.4 t-jet bosch me7.9.10 in english robotchip 15 1,160 08-28-2018, 07:45 PM
Last Post: Gianjiji
