Please note that, guests have limited sections to view!!!
  • 3 Vote(s) - 3.67 Average
C4 1.6HDI esp light on
#1
Citroen
Have strange problem C4 Picasso 1.6HDI Picasso edc16c34
When i start a car came ESP light on and are fault code:
D208 - can massage engine control unit faulty
I cheked :
1 - engine ecu - but in ecu are 0 faulty codes .
2 - cheked near battery wiring - ok.
3 - Cheked BSI wiring - ok
4 - Cheked ABS/ESP plug and wiring - ok.
5 - Tested Can comunication 120omh - ok
6 - Cheked egr plug wiring - ok
Maybe some one know were could be a problem? I add readed ecu dump ,maybe this file changed or no original.
P.S - i read in forum what this can be EGR problem ,but in my case i dont have in engine ecu fault code.
thank you all for help.
c4 edc16c34can original 1037386157.rar
File Type: .rar
Downloaded: 3 times
Reply
If someone changed the ESP module and not from the same car you can get the fault
Reply
Thanks given by: DjRomeo
#3
(06-13-2018, 04:03 AM)DjRomeo Wrote: Hello,
I cheked :
...you file not ori
not correct egr_off
Reply
Thanks given by: DjRomeo , jahacmm
#4
I cheked :
...you file not ori
not correct egr_off
with this file i dont do anythink , i read from car and dont turn off egr ore dtc.
So problem is bad file ore egr off ?
Could you help me with this file?
Reply
Thank you all, Solved!
Reply
Thread Author Replies Views Last Post
  Citroen Xara picasso 1.6hdi 2005y economy mode problem engine don't start krzysdro 3 1,890 09-04-2018, 07:41 PM
Last Post: leandrito
Citroen Citroen C4 2007 fog light alllex21 4 82 05-26-2018, 02:00 AM
Last Post: pagautas
Peugeot start problem peugot 407 1.6hdi webmusta 10 149 05-11-2018, 12:40 PM
Last Post: diagnostix
Citroen Citroen C5 1.6hdi 2005 Dtcs removing Egons100 1 88 04-01-2018, 10:34 AM
Last Post: Alex_vti
Peugeot Peugeot 307, 1.6hdi, P0087,P0093,P1113,engine sometimes cuts off grmsek.damjan 14 459 03-25-2018, 05:35 AM
Last Post: grmsek.damjan
This forum is for experimental & educational purposes only. As such, it is not acceptable whatsoever to post any software that requires a license on this forum. If any member does this, she/he will be revoked her/his membership forthwith. The forum greatly appreciates the cooperation of its members on this critical issue.
Best Viewed with Chrome.
