  • 22 Vote(s) - 3.23 Average
C4 HHTWIN Will not launch!
Hello guys,
Using XDOS 07-2016. Windows 7 Pro x86.
Used Dietrih's new solution from here:
-http://mhhauto.com/Thread-Xentry-OpenShell-XDOS-HHT-for-C4-Final
I ran the EXE file; restarted my computer.
Now: When I go through DAS on my w210, I select the ME (not quick test) and DAS then tries to open HHTWIN. The cursor shows the computer is working, but nothing comes up. I have firewall, UAC, and defender turned off.
I then went to C:\Program Files\Mercedes-Benz\HHT and launched HHTPKW.exe - nothing happens. No error or anything.
Any ideas? Searched for a couple of days now. I cannot find anyone with the same problem.
Thank you!
reinstall hhtwin
Art Tup
(11-03-2016, 01:10 AM)art_arev Wrote: reinstall hhtwin
Ok I will try again thanks Smile
Just reinstalled HHTWIN, same thing. Any ideas?
This is a brand new fresh install too... no unnecessary shit.
I'm problem on that to, anyone have solution?
I reinstall from scratch Windows 7 Ultimate X86, XDOS 7.2016, HHT-Win from Dietrih...
If I helped you, please press [Image: THANKS.png] and [Image: RATE.png] thank you!!!
Try to manually start HHT by clicking executable file.
REVERSE ENGINEERING | SOFTWARE ENGINEER
yes it the only way to start HHT, from DAS says “HTT-WIN is not available in this system”.
Some missing ini files I guess.
Mine is different.... I click the hhtpkw file, it does the same thing.
Just sits there working... nothing opens. DAS says it opens HHT. This is a drive problem I foud out with my motherboard
Gigabyte z170n wifi.... good new board but not compatible with TONS of stuff.... I have to change it for HHT.
Irik: For yours, you need to run openshell patcher and apply HHT, otherwise you need to point DAS to hhtwin directory
Thanks given by: iRik
