  • 26 Vote(s) - 2.69 Average
C4 SDConnect Problem
Hey guys, got a SDconnect C4 from Obd2buy.com - Seems good, good quality, fast unit - Yudi helped me get it set up, and last week I used but when I came into the shop this morning I couldnt get windows wireless network manager to find "Road24h". The unit works with Ethernet cable - just not wirelessly and I havent changed any settings.
Any ideas?
did you bought the one with the laptop or without ?
(08-01-2016, 09:13 PM)miau42 Wrote: did you bought the one with the laptop or without ?
Without laptop.
Anyways I got it working. Previously had someone start helping set up then they stopped. Basically they configured it for wired and then i messed it up.
Here's how I properly set up my brand new c4 mux.
1. Use Glintweb Xentry Patcher 3.1, applied C4 switches. C4 fixes.
2. Connected C4 via ethernet read what IP your SD connect is assigned to via ethernet. ie. 174.xx.xx.xxx; make note of it.
3. Open Network and sharing center
4. Click change adapter settings.
5. Right click on ethernet connection to C4, click properties
6. Click on Internet Protocol Version 4 (TCP/IPv4), click properties.
7. Select "Use the following IP address" and "Use the following DNS server addresses"
8. For IP Address: go two digits over whatever ip was assigned to your C4. If your C4 in the SD connect toolkit was for instance 174.xx.xx.115, in your IPv4 properties, make the op address 174.xx.xx.117. For Subnet Mask: 255.255.255.0
9. Do not edit Preferred DNS or Alternate DNS, leave blank.
Now it works by ethernet, go into SD connect toolkit, go to WLAN settings for ROAD24H, make note of the IP; 192.168.2.10.
1. Set password type for ROAD24H as HEX, and make password aaaaaaaaaaaaaaaaaaaaaaaaaa (26 a's).
2. Open Network and sharing center
3. Click change adapter settings.
4. Right click on WIFI adapter, click properties
5. Click on Internet Protocol Version 4 (TCP/IPv4), click properties.
6. Select "Use the following IP address" and "Use the following DNS server addresses"
7. Now for IP address: 192.168.2.12
8. For Subnet mask: 255.255.255.0
9. Save properties.
10. Save SDtoolkit properties.
Now: Sarrukin made the best guide for the rest of this setup:
(11-20-2015, 11:27 PM)Sarrukin Wrote: Try this
It worked for me
To save an ad-hoc network and its network key on the guest computer (running Windows 7)
Note down the SSID, security type, encryption type and the key of the ad-hoc network.
Disconnect your connection to any wireless network and switch off/disable your wireless device. Turn on/enable your wireless device but don't connect to any network. (Thanks GK.)
Click on the network icon in the taskbar.
Click Open Network and Sharing Center > Manage Wireless Networks > Add.
Click "Manually create a network profile". (This may look silly but we really are going to create an infrastructure network now.)
Enter the network name (SSID), security type, encryption type (if any) and the key that you noted in step 1.
Uncheck both checkboxes ("Start this connection automatically" and "Connect even if the network is not broadcasting".) [Note that you cannot have the connection start automatically. If you try to have it checked, step 10 will fail. A different way to start it automatically during system boot is described below.]
Click Next > Close. Your connection must appear in the list with the icon suggesting infrastructure (two big screens connected to a tube). Don't worry about it.
Click Start, type in "cmd" in the search box, press Enter.
In the Command Prompt, type in "netsh wlan set profileparameter name=NetworkName ConnectionType=IBSS", exactly as shown, without quotes, except you must substitute NetworkName with the SSID (network name) of your ad-hoc network.
If everything went well, you'll see that the icon has now changed to an ad-hoc icon (three small screens connected to each other) in the Manage Wireless Networks window.
Turn on/enable your wireless device, and try connecting to the Ad-hoc network. You will notice that you no longer need to enter the network key.
To automatically connect to a saved ad-hoc network during Windows boot (can be applied to both guest and host computers running Windows 7)
Click Start > point to All Programs > right-click Startup > click Open. (You may choose Open All Users instead if you prefer).
Right-click an empty space and click New > Shortcut.
Type in "netsh wlan connect NetworkName". Once again, NetworkName must be substituted with the SSID of your ad-hoc network.
Click Next and enter a fancy name such as "Connect to NetworkName" or something like that.
Click Finish and you're done. This shortcut will run when Windows starts up, giving you a very brief flash of the black command window, followed by your computer connecting to the ad-hoc network if it is available. Tip: You can also pin the shortcut in your taskbar or copy it to the desktop to easily connect to the network any time you want.
Note: You will probably need Administrator access to complete some of the steps above (in both procedures).
Hope this helps someone in future Smile
Thanks given by: Marcos , autoseek , amgdvl
