  • 3 Vote(s) - 2.67 Average
C7 cat acert runs erratic when not in cold mode
06-13-2018, 05:36 AM
Hello all I am working on a c7 engine sn kal31337 and have replaced injectors and heui pump, the timing sensors and ecmdue to the ecm voltage droping under a load. The truck dose not misfire any more but when it comes out of cold mode the sound of the engine changes and you can't control the throttle. Fuel pressure is at 68psi steady coolant temp is 140 and the ecm is reading the same as the same as temp gun. Is there a possibility that the new ecm could have a corrupt file due to the information used out of the old ecm? Any thoughts or help would be greatly appreciated. Thanks in advanced
06-13-2018, 07:29 AM
RE: C7 cat acert runs erratic when not in cold mode
1. check ECM active code
2. check Engine speed sensor (Low and up), you may exchange them, maybe you plugin wrong
3. replace ECM
 Thanks given by: Redman550
06-13-2018, 03:43 PM (This post was last modified: 06-13-2018 03:48 PM by Redman550.)
(06-13-2018 07:29 AM)jokey Wrote:  1. check ECM active code
3. replace ECM
No active codes
Will switch wires on timing sensor's in the morning
Just replaced the ecm with a new one two days ago
I will report back in the morning
Thanks for the help
06-15-2018, 03:41 AM
Maybe check or change the IAP sensor?
If it's not broke...then don't fix it
07-22-2018, 07:20 AM
Sorry that it has been so long getting back to this just wanted to tell you that we went back and reset the computed timing and that took care of all the drive ability problems thanks for all the help and suggestions
 Thanks given by: Nitrous383 , Koecon
  FREE DLB 2017 God mode and NED WITH CRACK ghostman 14 1,937 09-19-2018 08:14 AM
Last Post: am2000am
  Difference between China CAT Com 3 & Original CAT COM 3 Adapter r.kelly 12 1,185 09-13-2018 08:56 PM
Last Post: kuracnabiciklu
  Volvo tech tool 1.12 dev mode question Patricks 2 155 09-10-2018 08:30 AM
Last Post: naxnaxnax
  anyone tried Cat Program 170-8239? Or pdi acert 2902192? binderman01 9 214 08-24-2018 06:34 PM
  CAT Service Manuals_ C7/C11/C15/C16/C18 Acert B2_diesel 0 217 08-18-2018 04:47 PM
Last Post: B2_diesel
