  • 43 Vote(s) - 3.28 Average
CAT FLS/FTS C12-440
Hi, i have a C12-440 and we recon"d the injectors, but the truck is smoking black when the turbo kicks in... what differences would it make if i can adjust the FLS/FTS... would i be able to decrease the HP and get it to stop smoking..
How much HP do you actually adjust with the FLS/FTS, say if the engine is 440HP... would you be able to get it down to say 400HP.. and see if the black smoke is better....and were do i go... up or down.....
Any help would be great thanks...39Fing32
.html
20526326IK_20141202083510-FPS.html
67
973 bytes
653 DIESEL FUEL INJECTION SPECIALIST049
Hi. thanks man.... i have set the injector fuel the same as a new injector.... i'm running a Hartridge AVM2-PC and the fuel delivery from a new cat injector is about 145cc... and that is what i have set my injectors to...
I can't understand, it is only on the C12 engines that i am getting this problem,
all the other engines like C13/15/18/27 runs perfectly fine.. no smoke and lots of power... but the C12 is giving me the beans.... the standard fuel setting is about 145cc, if i set it down to 120cc the truck is starting to show rough idle and battles to start.... if i set it to 160cc i smokes the whole road looks like a steam train... that's why i though i can just fiddle with the FLS/FTS to see if i can just get the smoke down a bid, the power is good .....39
what bench are u running your injectors on and how many cc fuel do set your C12 injectors to.....
Listen
