  • 3 Vote(s) - 3.33 Average
CAT passwords not generating
AA+john-deere-utility-mat+(7)
Having trouble getting this keygen to produce passwords. I noticed a little status symbol at the bottom of the kg is red? i've seen it green on other screenshots. Why is mine red and why wont it generate a PW? something wrong with the parameters I entered?
P.S. i've tried on both windows 7 and a VM running XP. no luck. still same result
File Type: .png
Downloaded: 70 times
Red dot means it's not working .. most of the time it has to be run with winxp or AMD processor .or virtual box
AA+john-deere-utility-mat+(6)
(07-13-2018, 02:54 AM)sp33d Wrote: Red dot means it's not working .. most of the time it has to be run with winxp or AMD processor .or virtual box
here it is not working in my virtual machine XP with single core AMD processor
File Type: .png
Downloaded: 50 times
Make sure you have virtualization enabled in bios on your computer. Also, run as administrator. You shouldn't need a vm either. I use mine on windows 10 all the time. Just make sure you run as admin.
Thanks given by: diagnostix , mcartier
#5
test running as administrator works for me in w10 pro 64 bits
PM info Soft 2018
ET2018A KG LOCK/UNLOCKED
VOLVO PROSIS 02.2018
CAT SIS 08.2018
SDP3 2.36 x32/x64
HYUNDAI ROBEX 2017
CNH EST 8.7
Telegram @mcartier80
DONATE
thanks & rep
Thanks given by: ToMiBoY
#6
Run as administrator. Sometimes playing with compatibility mode is required too
  2.6 PTT databases passwords fang88 1 373 10-04-2018, 02:51 AM
Last Post: RAMZEZzz
  Difference between China CAT Com 3 & Original CAT COM 3 Adapter r.kelly 12 1,314 09-14-2018, 10:56 AM
Last Post: kuracnabiciklu
  Perkins Factory Passwords codeman256 0 177 09-13-2018, 01:52 AM
Last Post: codeman256
  cat factory passwords new meton 8 660 09-12-2018, 03:21 PM
Last Post: ronshamal
AA+john-deere-utility-mat+(7) CAT ADAPTER 3(clone) Not connected costas68gr 29 15,184 08-08-2018, 05:35 AM
