  • 7 Vote(s) - 2.29 Average
CHANGE VIN in Camera
I have installed a used one.. A0009057402 and it wont comunicate with CGW. Was told its because of old cars VIN coded in it. Wich also means I cant calibrate it. Is this the case? Is there ANY way of changing VIN in it? Vediamo?
Chris
CKM Car Design
I don't think there is a vin storage in camera . Just activate in CGW the camera option with vediamo or xentry I think
(05-31-2018, 01:44 PM)kminhtri Wrote: I don't think there is a vin storage in camera . Just activate in CGW the camera option with vediamo or xentry I think
It is activated since start I guess. Just replaced the broken one.
Chris
CKM Car Design
Ok, maybe it wasn't a broken camera no ? wiring?
Since I can SCN code it to car online I think wires should be fine..
Chris
CKM Car Design
Ok, don't know Sad
(05-31-2018, 01:56 PM)MBSCA Wrote: Since I can SCN code it to car online I think wires should be fine..
u got VIN error in xentry dtc? U cant do scn in that case. Check current and original VINs with vediamo, if current vin is urs then not vin problem
SPECIAL FILES DATABASE FOR VEDIAMO/DTS MONACO
ADBLUE, DPF, CAT, VMAX OFF
VIM 205 213 222
Thanks given by: fatal1ty
(05-31-2018, 11:27 AM)MBSCA Wrote: I have installed a used one.. A0009057402 and it wont comunicate with CGW. Was told its because of old cars VIN coded in it. Wich also means I cant calibrate it. Is this the case? Is there ANY way of changing VIN in it? Vediamo?
No, it's not the case. I've also installed a used camera in my car and it's working perfect. No need to change the VIN.
Maybe check the radar decission unit for errors.
Is that the distronic sensor? Only have errors on camera. Not in CGW or anything else. Just says camera dont comunicate with CGW.
Chris
CKM Car Design
Thanks given by: Calin_M
Yesterday, 05:14 PM
Yesterday, 02:38 AM
07-02-2019, 06:57 AM
06-25-2019, 01:04 PM
