Hello members,
I'm stuck at a big problem. I have a CLK55 AMG, which i converted its engine into a m113k of E55 AMG. The car is running perfectly without any issues. After a week the owner washed the engine, after several days the fan stopped working suddenly, the ABS and ESP light came on with the fault code "Check power supply of control unit..."
Don't ask me what did i do, ask me what i didn't. Have replaced the ESP ECU with 3-4 ECUs. Changed ABS pump, new Bosch battery, engine ECU, transmission ECU, front SAM, checked the power supply of the ECU and all works 100%.
The code is stored. After erasing, if you drive the car for 20 meters the light will come back with the same error. Checked wiring and all grounds to ESP...
I don't know if someone had a similar problem or could help me.
I will be very thankful for you mates and thanks in advance.
Regards
Regards
