  • 5 Vote(s) - 3 Average
CLS PROBLEM
HELLO I HAVE A MERCEDES CLS 320 CDI WITH A PROBLEM IN THE SPEED BOX I CALLED THE STAR AND APPEARS 2 EVENTS IN THE CDI (2211) AND IN THE APR (4751) AND THE CAR DOES NOT MET CHANGES. SOMEONE CAN HELP ME
What is speed box ?
I think you mean gear box (right)
MB Star2 Star3 Remote coding Anti Theft pin Map pin Renew FBS3 without special tool https://linktr.ee/SebaTechGeorgia
The worst description of the problem I just saw.
Please, write verbatim, what Star Diagnosis say.
Thx
Thanks given by: danrad , Mercerwin
Please first go and learn how Daignostic car. Then go and learn how to write. perhaps maybe then we can help you.
Thanks given by: Mercerwin
YES ,IS GEAR BOX
ABR MODULE-4751 - NO MESSAGE CAN BE RECEIVED BY THE COMMAND MODULE MODULE COMMAND OF TRANSMISSION
CDI MODULE-2211-001-NO MESSAGE OF THE CAN HAS BEEN RECEIVED BY THE EGS COMMAND MODULE
Please upload screenshot
(03-20-2017, 11:35 PM)toyss Wrote: YES ,IS GEAR BOX
Sounds like it has no communication with the EGS trans control unit.. check power and ground at the trans electrical connector, check for hi and low CAN voltage.. if all good, replace the trans conductor plate (which has the egs built into it), the flash and code online..
Thanks given by: Mercerwin , toyss , W214
