xEryx
Location OfflineJunior Member
-1
Thanks Given: 52
Thanks Received: 9 (6 Posts)
63
05-25-2026, 12:58 PM
I puchased a DRVU kit from a seller on AliBaba to retrofit and he sent me a CPC unit instead but that was months ago so he’s not willing to exchange. CPC PN: 0009016202. I know this same PN is used on DRVU as well because the module is the same.
Does anyone know if it can be flashed from CPC to DRVU? I connected it to the CPC wiring and made connection in DTS with CPC_NG.smr-d but when I go flash programming and add DRVU temp flash data, it makes noise and doesn’t add.
I did try to add CPC flash files and it took those.
Thanks.
120
Thanks Given: 424
Thanks Received: 624 (483 Posts)
1,359
13
05-25-2026, 02:42 PM
(This post was last modified: 05-25-2026, 02:42 PM by trigital.)
(05-25-2026, 12:58 PM)xEryx Wrote: Hello,
Thanks.
0009016202 can be flashed with proper SW, depending on your VIN to become DRVU
MBRetrofit Map Codes, Remote Star3 Coding
1,337
Thanks Given: 670
Thanks Received: 7082 (2890 Posts)
5,776
36
There is no communication with the interface; information is lacking to know why.
xEryx
-1
Thanks Given: 52
63
I’m using sdconnect clone, I’ve been using Xentry with no issues for years and I know it worked last time I was trying to figure out the module last Saturday. DTS has no issues scanning which makes me think is an Xentry issue but nothing has changed with my installation in the last week.
