Cadillac escallade 2021
Hello brothers
I have cadillac escllade 2021
Car crank but no start
I changed new fuel pump
But same issue
How i can diagnose fuel pump control unit ??
Or where is its relay
Then how i can jump start bypass relay to test car ???
Regards
there is control module used to control it, you should use gds2 diagnostic ti check it
Thanks given by: localmode
(05-01-2025, 11:32 PM)Mraze Wrote: there is control module used to control it, you should use gds2 diagnostic ti check it
Can use autel maxisys pro ??
Or ultra ??
Or ultra ??
yes you can use that as long as you have communication with the fuel pump module
If can help
Please send me fuel pump control wiring diagram
Regards
05-19-2026, 11:58 AM
Opel
05-15-2026, 01:16 AM
