Can anyone Help with ISTA-P E60 Programming Error.
Hi Guys,
Im really stuck. Please help!!
Heres the Details:
The Module is: KOMB60
Part number of basic control unit: 6974593
Part number of programmed control unit (actual) 6974577
Part number of programmed control unit (specified) 9197107
I programmed a 2005 BMW 530D (E60) with ISTA-P V3.66 using a Genuine BMW Icom Next & MOST Adapter.
All modules were successfully updated with the exception of the KOMBI. I had the following Error:
Global.VehicleCommunication.CoAPI.1060 (CoAPI) - Fault in the encoding process description file.
I tried a few times but results were the same.
I then tried with Winkfp.
I selected update ZUSB in Comfort mode and selected the KOMBI ECU family.
Winkfp then tried to program the car using the following files:
PABD: 16KOMB60.ipo
P-SGBD: 10FLASH.PRG. (This one seems wrong??)
It then gives me a
Error: 209 UIF can not be read!
2020 Error ECU does not answer IFH-0009: No response from control unit 10FLASH.
2020 Error ECU does not answer SG_AIF_LESEN
I have attached a few images.
Any Help would be really appreciated.
Still struggling. I have reinstalled the programs, used new SP-Daten files to rule out any corrupted data files.
Still getting the same error.
01-05-2020, 01:26 AM
01-04-2020, 05:59 PM
01-01-2020, 12:56 PM
Nissan
12-30-2019, 06:25 PM
