  • 1 Vote(s) - 2 Average
Can't connect to W212 AMG
Hello Members,
I tried to connect my Xentry to a E-Class W212 AMG. When i connect it reads the vehicle type but when i get further in the process it won't detect ignition status and VIN. Does anyone have a idea what my problem can be  ?
Kind Regards,
Diagnostic80
In my case, it was the obd cable from the mux.
(10-11-2018, 03:38 PM)i860 Wrote: In my case, it was the obd cable from the mux.
I tried my launch tester and it won't connect either. I think problem is in the car but OBD power is OK.
Test the obd, i think nr 16 is +
Dead CGW
  • SW Seed\key calculation. Vediamo licence. VGS\MED\SIM\KI hard coding.
  • HW Genuine StarDiag-SDConnect-eCom sale\repair\parts\setup
Front Sam(ZGW) damage - can line, water, or broken software.
I found the problem. It was a fault in xentry! Thanks everybody for your reply  Tup
Will be nice to share how you fix the problem in xentry.
Mercedes Benz Updgrading to SD Connect C4 or C5? vladc77 2 104 9 hours ago
Last Post: vladc77
Mercedes Benz Retrofit W212 Distronic plus miso6824 13 2,571 Yesterday, 12:54 PM
Last Post: Ilja
  W212 REAR CAMERA CBF FILE audiomeca 2 106 10-13-2018, 05:39 PM
Last Post: audiomeca
  SD Connect C4 vs. Xentry Connect C5 MD20 6 255 10-11-2018, 10:05 PM
Last Post: MD20
Mercedes Benz How to: Disable Start/Stop W204 W212 Benzdriver23 44 10,121 10-11-2018, 03:33 PM
Last Post: ken_dos
