Cannot disable 2017 Challenger rear left light fault check
Need disable rear lights fault check (Diagnostic input) on 2017 Dodge challenger
I few times do it on 2019+ challengers using AlphaOBD software without any problems.
Maybe someone can help me solve this problem?
Here is not changed BCM settings:
ECU Part Number: 68309502AC
Hardware number: 68309502AC
Hardware Supplier Identification: Continental
Software Logical Block Supplier Identification: Continental
Active Diagnostic Status Of ECU: Running in Application mode
Gateway: Yes
Vehicle Configuration Programmed Status: Yes
Last Programmed Status: Manufacturing
After Market ECM Detected: Default
ECU Qualification:
Sense-Ambient Light Dimmer Wheel: Yes
Sense-Reverse Switch: No
Sense-Door Lock Switch Front Driver: Yes
Sense-Door Lock Switch Front Passenger: Yes
Sense-ERS Switch: No
Sense-Flipper Glass Ajar: Yes
Sense-Fuel Level Sensor #2: Yes
Sense-Hood Ajar Switch: Yes
Sense-Hard Top/Stealth Input: No
Sense-Liftgate/Trunk Ajar: Yes
Sense-Trunk/Flipper Glass Release Switch: Yes
Sense-Rear Wiper Park Switch: No
Sense-Washer Fluid Level: Yes
Sense-Flipper Glass Release/Sunshade Switch: No
Sense-ESP Off Switch: No
Sense-Cargo Lamp Switch: No
Police Passenger Unlock Motor Present: No
Control-Headlamp Leveling: No
Control-Baggage Comp Lamps: Yes
Control-Diesel Cabin Heaters 1-3: No
Control-ESCL: No
Control-Diesel Fuel Heater Relay: No
Control-Flipper Glass #2: No
Control-Foot Well Lamps: Yes
Control-Front Fog Lamps: Yes
Control-Headlamp Washer Motor: No
Control-Passenger Airbag Off LED: No
Control-Rear Fog Lamps: No
Control-Rear Turn Lamps: No
Control-Rear Wiper Motor/Flipper Glass #1: No
Control-Run/ACC Relay #2: Yes
Control-Side Repeaters: Yes
Control-Sunshade: No
Control-Trunk/Flipper Glass Relay: Yes
Control-UGDO Feed: Yes
Control-Trailer Tow: No
Control-Dedicated DRL: No
Control-VTA Indicator Request: Yes
Control-Passenger Airbag LED: No
Adjustable Pedals Present (Non-memory): No
Inverter Present: No
Intrusion System Present: Yes
Remote Start Present: Yes
Tip Start Present: Yes
HID Headlamps Present: Yes
Auto Headlamps Present: Yes
Rain Sensor Present: No
Remote Compass Present: No
EC Mirror Present: Yes
Cruise Feature Present: Yes
RKE System Present: Yes
SKIM System Present: Yes
Police Vehicle: No
Military Lighting: No
AC Present: Yes
Rear Doors Present: No
Electronic Shifter Power Feed Present: Yes
[b][b][b][b][b]____[/b][/b][/b][/b][/b]
Car configuration
VehConfig 1:
Model Year: 2017
Vehicle Line: LA - CHALLENGER
Country Code: USA
Left/Right Hand Drive: Left Hand Drive
Drive Configuration: 2WD Rear
Emode Present: No
Auto Highbeam: No
Body Style: 2-Door sedan
Maximum Vehicle Speed (0 - 500km/h): 380,000 km/h
Shifter Type: 5 pos Polystable Eshifter (PS5)
PTS Display Type and Location: Instrument Cluster PTS Display
Performance Pages Present: No
Special Package: Premium (Default), or SXT or R/T, or Laramie
Headrest Present: No
UREA/SCR System Present: No
PTS Configuration: Rear
Rear View Camera: Yes
CHMSL Camera: No
Hill Descent Feature Present: No
Select Speed Control Feature Present: No
VehConfig 2:
Power Inverter Type: No Power Inverter
Thatcham Present: No
Run Flat Tires Present: No
Maserati Vehicle Mode: Signal Not available
Passenger Airbag Disable Switch Present: No
Air Conditioning Present: Yes
Cruise Control Present: Yes
Flipper Glass Present: No
Full Size Spare: No
Off-road Capable: No
Special Package: No Package
ECO Indicator Present: No
Drive mode feature configuration: No
Memory Drive Mode Sub-feature Configuration: No
ESC Drive Mode Sub-Feature Configuration: No
ECM Drive Mode Sub-Feature Configuration: No
Secure Park Feature Present: No
Configuration For Performance & Gear Shift Indication: Not Present
Max Load Inflation Pressure Rear Tire (0-126PSI): 32,000 PSI
Max Load Inflation Pressure Front Tire (0-126PSI): 32,000 PSI
Light Load Inflation Pressure Rear Tire (0-126PSI): 32,000 PSI
Light Load Inflation Pressure Front Tire (0-126PSI): 32,000 PSI
VehConfig 3:
Police Lighting Feature: No
Power Lift Gate Present: No
Power Right Sliding Door Present: No
Power Left Sliding Door Present: No
Sunshade Present: No
T-Case Type: Not Present
Wheel Base: Short wheel base (120'' Ram Truck)
FOBIK Safe Enable: Yes
ELV Present: No
Fuel Capacity (36-290 L): 70,000 Liters
Window Express Feature Configuration: No window express feature
Adjustable Pedal Feature Present (non-Memory): No
Auto Headlamp Feature Present: Yes
Door Alert Feature Present: No
Two Fuel Sending Units Present: Yes
Vehicle is an SRT: No
Disable Display of Radio Clock: No
Chassis Type: Type 44
Display Outside Temperature Present: Yes
HVAC Configuration: Dual Zone ATC
Vehicle Brand: Dodge
Display Compass Heading Present: Yes
Interior Electrochromic Mirror Present: Yes
ESCL System Present: No
High Intensity Discharge Headlamps: Yes
Secondary Lock Present: No
Liftgate/Trunk Type: Trunk
Collision Mitigation System Present: No
Forward Collision Warning Present: No
Base TPM System Present: No
Premium TPM System Present: Yes
Paddle Shift Feature Present: No
Sport Mode Present: Yes
Auto Park Present: Yes
Passive Entry Present: Yes
Keyless Go Present: Yes
VehConfig 4:
Transfer Case High Ratio (0-16.382): 0,000
Axle Ratio (0-65.534): 3,077
Transfer Case Low Range Reduction Ratio (0-65.534): 0,000
Dynamic Tire Circumference (All or Rear) (0-65534 mm): 2242,000 mm
VehConfig 5:
Luci Feature Present: No
Dual Rear Wheel (DRW) Vehicle Present: No
Non-Regulated Tire Pressure Information System (TPIS) Present: No
Wait to Start Feature is Present: No
Ambient Temperature Sensor Location: CBC
Steering Ratio at Zero (0-25.4): 0,000
Steering Ratio at Positive Angle 1 (0-25.4): 0,000
Steering Ratio at Positive Angle 2 (0-25.4): 0,000
Steering Ratio at Positive Angle 3 (0-25.4): 0,000
Steering Ratio at Positive Angle 4 (0-25.4): 0,000
Steering Ratio at Positive Angle 5 (0-25.4): 0,000
Rear Door Lock Switch Present: No
Speed Limiter Present: No
Seat Belt Reminder Module Present: No
Child Display Present: No
Off-Road Pages Present: No
Ambient Lighting Present: Yes
Semi Automatic Parking System Present: No
Park With Stop Present: No
VehConfig 6:
Analog Door Sensor Configuration: None
Brake Type Configuration (M156/7): Signal Not available
Air Quality System Present: No
Steering Ratio at Negative Angle 1 (0-25.4): 0,000
Steering Ratio at Negative Angle 2 (0-25.4): 0,000
Steering Ratio at Negative Angle 3 (0-25.4): 0,000
Steering Ratio at Negative Angle 4 (0-25.4): 0,000
Steering Ratio at Negative Angle 5 (0-25.4): 0,000
Dynamic Tire Circumference, Front Only (0-65534 mm): 0,000 mm
VehConfig 7:
Lane Departure Warning Present: No
Transmission Drive Mode Feature Present: Yes
Paddles Lock-out Feature Present: No
Dynamic Steering Torque Present: No
Super Trac Pack Present: No
E-Shifter present: Yes
Automatic transmission type: ZF 8-Speed
Shift Feature Autostick / Electronic Range Select Status: Autostick Present
Full Speed Range Forward Collision Warning Plus System: No
Type of adaptive Cruise Control (ACC) system present: ACC not present
Air Suspension Control Module (ASCM) has Suspenion: No
Air Suspension Control Module (ASCM) has Active Damping: No
Vehicle is Equipped with a Screen Off Soft Button: Yes
Red Key Feature Present: No
Transmission Equipped: Automatic transmission
TPMS Configuration: Logic 1 NHTSA Enable Warning
Terrain Switch Bank Module (TSBM) Present: No
ECUConfig 3:
Configuration Messages Status 3: Programmed
Rear Camera Present: Yes
DRL Customer Setting Option Present: Yes
Power Inverter Present: No
Front Park Assist Present: No
Front Heated Seats Present: No
Front Ventilated Seats Present: No
Country of Destination: MARKET 2 // United States of America
Cabin Equalization Curve: Premium 1 for Challenger (Alpine 8ch) (LA)
Hill Start Assist Customer Setting Option Present: Yes
Radio Apps Present: No
CTP Passive Entry Present: Yes
SDAR Travel Link Feature Present: Yes
DAB/DMB Present: No
Vehicle Theft Alarm (VTA) System Present: Yes
Heated Steering Wheel Present: No
Overdrive Switch Feature Present: No
Surround Sound Feature Present: No
Power Door Locks Present: Yes
Antenna Type: Active Primary and no secondary antenna
Hybrid Electric Powertrain Present: No
Disable CD Eject: No
Tow Haul Switch Feature Present: No
Hill Descent Switch Feature Present: No
PASS Call Feature Present: Yes
PASS Hands-Free Phone Feature Present: No
Radio Display On/Off Softkey Present: No
External Port Type: AUX + USB + extra USB
Splash Screen Type: Vehicle Brand
ECUConfig 4:
ECU Configuration 4 (0-3): 1,000
ERS Available: No
Rear Wheel Dually: No
Max Gear: Eighth Gear
Virtual Speedometer Units: Not Set
Speedometer Range Max Scale: Not Set
IPC Configuration Feature Present: No
PTO Present: No
Ambient Dimmer: No
Heated Seat Present: No
Split Shaft Present: No
Actual Gear Display: Yes
Manual Headlamp Leveling: No
CBC Features:
Tip Start Enabled: Yes
Dual Start Relay System Present: No
Wiper Service Position Enabled: No
Fuel Door Release Enabled: No
Trailer Tow Present: No
Quad Headlamps Enable: Yes
Horn Chirp Allowed: Yes
Bi Xenon Headlamps Enabled: Yes
Hazard Lamp Configuration: Latching
Park Lamp Loadshed Enabled: Yes
Front Fog Lamp Dropout Enabled: Yes
Combined Rear Lighting Enabled: No
Side Repeaters Enabled: No
One Touch Lane Changed: Yes
Exterior Light Loadshed Enabled: Yes
Front Wiper Park Enabled: Yes
Rear Wiper Park Enabled: No
Reversible Washer Pump Enabled: No
Single Element Tail Lamp: No
DRL Configuration: Europe DRL ECE 48.05_MY18
DRL Lamp Location: Turn Signal DRL
DRL Dropout Enabled: Yes
Tunnel Detection: No
Military Vehicle Present: No
LED Reverse Lamps Present: Yes
LED Stop Lamps Present: Yes
LED Rear Turn Lamps Present: No
LED Tail Lamps Present: Yes
LED Rear Fog Lamps Present: No
LED License Lamps Present: Yes
LED Front Turn Lamps Present: Yes
LED Front Fog Lamps Present: No
LED Dedicated DRL Present: No
LED Low Beam Lamps Present: No
LED High Beam Lamps Present: No
LED Front Park/Marker Lamps Present: Yes
Illuminated approach Enabled: No
Door Lock Switch Signal Front Left Usage: Driver Door Analog Ajar Switch
Door Lock Switch Signal Front Right Usage: Passenger Door Analog Ajar Switch
TCSM Present: No
Headlamp Wash Spray Duration (at 100 ms intervals): 1200ms
Headlamp Wash Interval: wash cycle #11
Headlamp Wash Shot: Single
Headlamp Washer Low Fluid Shut-Off Enable: No
Side Mirror Repeaters used as side markers: No
Intermittent Wiper States: 4 Intermittent Wiper position Switch
LED CHMSL Lamp Present: Yes
CBC Config I/O:
Ambient Light Dimmer Wheel Input Present: Yes
Low Beam Output Present: No
Backup-Reverse Switch Input Present: No
Front Driver Analog Door Ajar Input Present - Pin F9: Yes
Connector F Pin 23: Door Lock Switch Signal Front Passenger Present: Yes
ERS Switch/Inverter On/Off Switch Input Present: No
Connector F Pin 29: Horn Switch Present: Yes
Connector E Pin 15: Fuel Level Sensor #2 Input Present: Yes
Connector A Pin 11: Hood Ajar Switch Input Present: Yes
Rear Left Turn Lamp Diagnostics: No
Connector F Pin 21: Inverter Status Input Present: No
Connector F Pin 22: Manual T-Case/Analog Spare Input #1 Present: No
Connector F Pin 26: Trunk/Liftgate Ajar Signal Input Present: Yes
Connector G Pin 18: Left Rear Door Ajar Signal/RLS Analog In 3 Input Present: No
Trunk/Flipper Glass Relay Switch Signal Input Present: Yes
Rear Wiper Motor Park Switch Input Present: No
Connector A Pin 8: Washer Fluid Level Sense Signal Input Present: Yes
Connector E Pin 5: Sunshade Switch Input Present: No
Connector E Pin 31: ESM Present - Power Ignition Run: Yes
Connector G Pin 16/Connector E Pin 13: ESP Switch Input Present: No
Connector E Pin 35: Adjustable Pedal Motor Relay Output Present: No
Connector F Pin 6: Baggage Compartment Lamps Output Present: Yes
Connector D Pin 7: Diesel Cabin Heater #1 Output Present: No
Connector D Pin 9: Diesel Cabin Heater #2 Output Present: No
Connector D Pin 10: Diesel Cabin Heater #3 Output Present: No
Connector D Pin 11: ESCL Unlock Control Output Present: No
Connector D Pin 12: Diesel Fuel Heater Relay Output Present: No
Right Dedicated DRL Lamp/Right Signature LED Present/Right Front Turn Signal #2/Headlamp Leveling Output Present: No
Left Dedicated DRL Lamps/ Left Front Turn Signal #2/Left Signature LED Present : No
Connector E Pin 34: Flipper Glass #2 Output Present: No
Connector F Pin 7/Connector G Pin 24: Foot Well Lamps Output Present: Yes
Connector A Pin 01 and Connector D Pin 13: Front Fog Lamps Output Present: Yes
Connector D Pin 6: Headlamp Washer Motor Control Output Present: No
110/220 VAC Inverter Power Switch Input Present - Pin F35: No
Connector F Pin 38: Snow Plow Low Beam Relay Control LT0/Relay LSD Spare #1 Output Present: Yes
Connector E Pin 20: HID LSD Output Present/Relay LSD Spare #2 Output Present: Yes
Connector D Pin 24: Snow Plow LSD #3/Relay LSD Spare #3 Output Present: No
IOD ON LSD Output Present: No
Connector E Pin 10: Head Rest (IOD OFF LSD Output Present): No
Connector G Pin 23: Passenger Airbag Off LED Output Present: No
Connector E Pin 39/Connector F Pin 5: Rear Fog Lamps Output Present: No
Connector E Pin 4/Connector F Pin 32: Rear Park Lamps Output Present: Yes
Connector E Pin 3/Connector F Pin 42: Rear Turn Lamps Output Present: No
Auxliary Fuel Pump(Rear Wiper MTR Ctrl/Flipper Glass #1 Output Present): No
Connector E Pin 9: Run-ACC Y Relay #2 Output Present: Yes
High Beam Output Present: Yes
Connector E pin 8: Sunshade Control Output Present: No
Connector E Pin 42: Ram Box/Tail Gate Lock (Thatum Lock Output) Present: No
Connector E Pin 41: Ram Box/Tail Gate Unlock (Thatchum Unlock) Output Present: No
Connector E Pin 23: Trailer Backup Lamps Output Present: No
Connector E Pin 24: Trailer Tail Lamp Relay Control Output Present: No
Connector F Pin 36: Trailer Turn Stop Relay Control Left Output Present: No
Connector E Pin 22: Trailer Turn Stop Relay Control Right Output Present: No
Connector F Pin 4: Trunk/Flipper Glass Relay Output Present: Yes
Connector G Pin 15: UGDO Feed Output Present: Yes
Connector G Pin 2: Vehicle Theft Alarm (VTA) Warning LED Output Present: Yes
Connector A Pin 14: Washer Motor Control Right Rear Output Present/Front Camera Washer: No
Connector E Pin 11: Park Brake Input Present: Yes
Connector A Pin 24: Ignition UNLOCK RUN START Present: No
Connector E Pin 37: IOD Relay Off HSD (High Side) Present: No
Connector E Pin 7: IOD Relay On High Side Present: No
Connector D Pin 22/ Connector D Pin 23: Ambient Temperature Sensor Present: Yes
CBC Config I/O Usage:
ESCL Usage: ESCL
Connector F Pin 22: ANALOG SPARE INPUT #1 Usage: Manual T-Case
Connector G Pin 8: Trunk/Flipper Glass/Liftgate Release Outside Handle Switch/Upfitter Combined Function: Inside mounted Switch
Connector F Pin 41: Backup-Reverse lamp Left: Yes
Connector E Pin 1: Backup-Reverse lamp Right: Yes
Connector F Pin 5: Fog Lamp Rear Left/High Beam Shutter: Left Rear Fog Lamp
Connector E Pin 39: Fog Lamp Rear Right/High Beam Shutter: Right Rear Fog Lamp
Connector F Pin 42: Right Rear Turn Signal: Right Rear Turn Signal
Connector E Pin 3: Left Rear Turn Signal: Left Rear Turn Signal
Connector E Pin 8: Sunshade Control Usage: Sunshade control
Connector D Pin 1: Left High Beam Feed/Left Park Lamp Usage: Left Front Park
Connector A Pin 2: Right High Beam Feed/Right Park Lamp Usage: Aux High Beam
Front Driver Door Ajar Switch Signal Usage (Lamp Diagnostics): Left Front Lamp Diagnostics (M156)
Connector F Pin 28: Passenger Side Lamp Diagnostics/Door Ajar Switch Signal Usage: Right Front Lamp Diagnostics
Connector F Pin 27: Door Ajar Switch Signal Rear Left Usage: Disabled
Connector F Pin 6: Baggage Compartment Lamps Usage: Car Trunk Lamps
Connector F Pin 4: Trunk/Flipper Glass Relay Release Usage (IP Decklid Switch SIG on L's): Trunk/Liftgate Release
Connector F Pin 31: Right Rear Lamp Diagnostics/Right Rear Door Ajar Switch Signal Usage: Disabled
Connector D Pin 21: Brake Fluid Level Switch: 10K Parallel Resistor
Connector D Pin 12: Diesel Fuel Heater Relay Usage: Connect Output to Run Start Ignition Relay API (Truck Usage)
Connector F Pin 29: Flipper Glass Ajar Signal (Horn Switch input on LA): Horn Switch Input
Relay LSD Spare #1 Usage: HID Relay Control Left
Relay LSD Spare #2 Usage: HID Relay Control Right/M157 High Beam Relay Left
Spare LSD Relay #3 Usage: Snow Plow LSD #3
Connector A Pin 11: Hood Ajar Switch Signal Usage: 1K parallel resistor
Connector E Pin 30: ESP Switch/HSD Usage: Cargo Lamp Switch
Connector E Pin 21: Ignition Off Draw (IOD) Relay On LSD Usage: Snow Plow LSD #4
Connector E Pin 10: Ignition Off Draw Relay Off LSD Usage: (WK) Head Rest
Connector E Pin 7: Ignition Off Draw Relay On HSD Usage: Snow Plow Left Turn
Connector E Pin 37: Ignition Off Draw Relay Off HSD Usage: Snow Plow Right Turn Lamp
Connector E Pin 31: ESM Usage/TOPPER CHMSL: ESM
Connector E Pin 29: Back-Up Reverse Switch Usage: Reverse Switch
Connector E Pin 42: Thatcham Lock Usage: Thatcham Lock
Ram Box/THATCHAM UNLOCK Usage: Thatcham Un-Lock
Rear Left Door Ajar Usage: Analog Door Ajar Switch Rear Left
Rear Right Door Ajar Usage: Analog Door Ajar Switch Rear Right
Stop&Start Enable Switch Present: No
2014 CBC Config I/O & Feat.:
External Decklid/Trunk Switch/Analog Spare Input #2: External Decklid Switch
Connector F Pin 14: Right Sliding Door Switch Input (B-Pillar)/Analog Spare Input #3: Disabled
Connector F Pin 15: Driver Door Lock Switch/Analog Spare Input #4: Disabled
Connector F Pin 16: Passenger Door Lock Switch/Analog Spare Input #5: Disabled
Analog Spare Input #6: Disabled
Connector A Pin 7: Air Catcher LED Left: Not Present
Connector A Pin 5: Air Catcher LED Right: Not Present
Connector F Pin 19: Spare Relay LSD #4: Not Present
Connector F Pin 20: Spare Relay LSD #5: Not Present
Liftgate Lock: Not Present
Liftgate Unlock: Not Present
Connector F Pin 34: Switch Lamp Indicator #1/Spare HSD: Not Present
Switch Lamp Indicator #2: Not Present
Connector F Pin 43: Switch Lamp Indicator #3/Spare HSD: Not Present
High Beam Lamps Open Circuit DTC Enabled: No
Dedicated DRL Lamps Open Circuit DTC Enabled: No
License Lamp Open Circuit DTC Enabled: No
Reverse Lamps Open Circuit DTC Enabled: No
Stop Lamps Open Circuit DTC Enabled: No
CHMSL Lamp Open Circuit DTC Enabled: No
Front Park Lamps Open Circuit DTC Enabled: No
Rear Park Lamps Open Circuit DTC Enabled: No
Front Fog Lamps Open Circuit DTC Enabled: No
Rear Fog Lamps Open Circuit DTC Enabled: No
CHMSL Lamp Output Disabled: No
Diesel Fuel Heater Enabled: No
Manual Door Locks Present: No
Connector E Pin 48 (Tied internally to Connector A Pin16): Rear Wiper Motor Control Output Present: Rear Wiper
ERS Input Usage: ERS
Rain Sensor Module #2 Present: Yes
Humidity Sensor Long Present: Yes
Auto High Beam Module Location: None
ERS Input Present: No
License Plate Lamp Disabled: No
Connector F Pin 29: Horn Switch/Flipper Glass Ajar Signal Usage: Horn Switch Input
Signature Lamp Feature: Yes
Windshield Wiper Variant: Absent
CBC Extern.Light Calibr.:
Auto Headlamp On Threshold (0-5 V): 3,314 V
Auto Headlamp Off Threshold (0-5 V): 2,549 V
Left Side DRL Voltage Target: 7.0 V
Right Side DRL Voltage Target: 7.0 V
Left Low Beam Voltage Regulation: 13.8 V
Left High Beam Voltage Regulation: 13 V
Right Low Beam Voltage Regulation: 13.8 V
Right High Beam Voltage Regulation: 13 V
Left Front Corner Voltage: 13 V
Right Front Corner Voltage: 13 V
Left Rear Corner Voltage: 13 V
Right Rear Corner Voltage: 13 V
CBC Supplier EOL:
RKE Relock Trigger: No
PE Relock Trigger: Yes
FOB In Trunk Alert On Auth System Fault: Yes
FOB In Trunk Alert Search Timeout: Yes
FOB In Trunk Alert No Reply: No
Throttle Position (0-100%): 12,800 %
Trigger Count (0-15): 8,000
Vehicle Moving threshold (0-25 km/h): 16,000 kph
Engine Running Method: Engine Run Status
RPM Threshold (0-255rpm): 200,000 RPM
Heat Soak Flush Time: 120 sec
Ambient Stable Counter Limit: 90
Heat Soak Speed: 20 mph
Engine Hot (0-120 Deg.C): 83,000 Deg.C
Engine Off Clear Time: 0 min
Max Engine Time Off: Not defined
Temperature Offset (0-7 Deg.C): 0,500 Deg.C
Alarm - VTA Params:
Vehicle Theft Alarm (VTA) Last Status: Disarmed
Invalid Arm/Disarm Counter (0-7): 0,000
Tamper Alert: No
EE System Lock: No
EE Interior Release Switch Function: Yes
Vehicle Theft Alarm (VTA) Last Trigger: Unknown
Alarm - ITM:
ITM ECU Configuration B: 0,000
Siren present: Yes
Ultrasonics present: Yes
Tilt Sensor present: Yes
Brakes:
Brake System ECU Configuration A: Value 0
Wheel 18 Inch Overall ESC Maserati: No
Battery:
IBS Activate MWU: No
Battery Type: Battery ID 4
IBS Quiescence Current Limit (-250-0 mA): -250,000 mA
IBS Minimum Voltage Limit (0-25.4 V): 5,000 V
IBS Minimal Charge Limit (0-125 Ah): 10,000 Ah
IBS Standby Time (0-7620): 7620,000 sec
IBS Minimum Charge Limit (0-2500mA): 600,000 mA
Cluster:
Fuel Tank 1 Calibration, Full Datum for Fuel Voltage 1: 0
Fuel Tank 1 Calibration, 3/4 datum for Fuel Voltage 1: 0,000
Fuel Tank 1 Calibration, 1/2 datum for Fuel Voltage 1: 0,000
Fuel Tank 1 Calibration, 1/4 datum for Fuel Voltage 1: 0,000
Fuel Tank 1 Calibration, LFW datum for Fuel Voltage 1: 0,000
Fuel Tank 1 Calibration, Empty datum for Fuel Voltage 1: 0,000
Fuel Tank 1 Calibration, E Stop Datum for Fuel Voltage 1: 0
Fuel Tank 1 Calibration, Empty: 2%
Fuel Tank 1 Calibration, LFW: 8%
Cluster:
Fuel Tank 2 Calibration, Full datum for Fuel Voltage 2: 0
Fuel Tank 2 Calibration, 3/4 datum for Fuel Voltage 2: 0,000
Fuel Tank 2 Calibration, 1/2 datum for Fuel Voltage 2: 0,000
Fuel Tank 2 Calibration, 1/4 datum for Fuel Voltage 2: 0,000
Fuel Tank 2 Calibration, LFW datum for Fuel Voltage 2: 0,000
Fuel Tank 2 Calibration, Empty datum for Fuel Voltage 2: 0,000
Fuel Tank 2 Calibration, E Stop datum for Fuel Voltage 2: 0
Fuel Tank 2 Calibration, Empty: 2%
Fuel Tank 2 Calibration, LFW: 8%
Diesel Fuel Heater:
Time Key Off (0-120 sec): 0,000 Sec
Time Key On (0-120 sec): 0,000 Sec
External Temperature Key Off (-15 - 20 Deg.C): -15,000 Deg.C
Ignition Off Timer (0-255 min): 0,000 min
Time Crank Off (0-25 sec): 0,000 Sec
Vehicle Stop (0-10 km/h): 0,000 Km/h
Doors:
Global Windows Up: No
Global Windows Down: No
Sun Shade Present: No
Power Folding Mirrors Present: No
Heated Mirrors Present: Yes
Mirror Turn Signals Present: No
Driver Memory Mirrors Present: No
Passenger Memory Mirror Present: No
Electro-Chromatic Driver Mirror Present: No
Electro-Chromatic Passenger Mirror Present: No
Tow Mirror Present: No
Blindspot Mirror Present: Yes
Mirror Approach Lights Present: No
Door Map Pocket LED Present (Ambient Lights): No
Door Courtesy Lamps Present: Yes
Window Motor Type: No
Window Hall Sensors Present: No
Door Handle LED Present (Ambient Lights): Yes
Frameless Window Present: Yes
LIN and Misc:
Fobik Safe Alert No Reply: Yes
Fobik Safe Alert on System Fault: Yes
Fobik Safe Alert on Search Timeout: Yes
Panic Enabled: Yes
Compass Mounting Orientation: Right Side Up
Washer Fluid Level Voltage Threshold: 4.46 V
Fobik Safe Alert Per Ignition Cycle Counter: 2
IBS Present: Yes
RCM Present: No
Humidity Rain Light Sensor Present: No
Manual Trans Present: No
Smart Beam Present (AHBM): No
DC to DC Converter Present: No
Auto Relock Time (1-255 sec): 60,000 sec
Vehicle Theft Alarm (VTA) System State: VTA
Electronic Overhead Module (EOM) Present: No
DC to DC Converter #2 Present: No
Illuminated Approach Interior Lighting Target Percent: 125 (62.5%)
Illuminated Approach Headlamp Target Percentage: 165 (82.50%)
Illuminated Approach Taillamp Target Percentage: 165 (82.50%)
Illuminated Approach Interior Lighting Ramp Up Time: 13 (260 ms)
CRVMM Present: Yes
EVIC Switch Module Present: Yes
Compass Mounting Angle (0-360 Deg.): 0,000 Deg.
Memory:
Memory Adjustable Pedals Present: No
Tilt/Telescope Steering Present: No
Memory Seat Present: No
Rear Heated Seats Present: No
Front Vented Seats Present: No
Heated Seat Material Type: Cloth
Heated Wheel Material Type: Full Leather
Miscel. Params:
Rolls Mode Ignition Cycle Counter (0-255): 0,000
Engineering Timer (0-7650 msec): 0,000 ms
Engine ON, ASD High Time (0-254 sec): 0,000 sec
Ignition Run/Start Rationality Time (0-25.4 sec): 0,000 sec
VIN Handshake Lock: No
Wiper Service Pulse Delay: 150ms
Disable Sport Mode Plus: No
After Market ECM Detected: No
Window Drop Timeout (0-65535 msec): 0,000 ms
Brake Switch lamp timer: 0,000 min
Parktronics:
Park Assist Tuning Set: Base 1
Plant/Service Mode:
Shipping Status: Customer Mode
Powertrain:
Vehicle is Equipped with Dosing Control Unit: No
Vehicle is equipped with Variable Geomeric Turbo Actuator: No
ECO Mode Configuration: Not Available
Dual Alternator Present: No
Powertrain ECU Configuration B (0-255): 1,000
Safety:
ODS Present: No
Driver Kneebag Present: No
Passenger Kneebag Present: No
Curtain Airbags Present: No
Tow Hooks Present: No
Side Airbags present: No
2nd Row Seat Airbags Present: No
Delete Passenger Seat Present: No
1st Row Seat Side Airbags Present: No
Integrated EPP Present: No
BUX Market: No
Steering:
Suspension ECU Configuration A: 0,000
Suspension ECU Configuration B: 56,000
Tip Start Params:
Tip Start Time Out (0-50 sec): 0,000 sec
RPM Threshold (300-555): 300,000 RPM
Tip Start Time Out Diesel (0-50 sec): 0,000 sec
Wiper/Washer:
SSI Delay 1 Factor (6250-11250): 0,000
SSI Delay 2 Factor (20-50): 0,000
Rear Wiper Wetting Timer (100-500 msec): 0,000 ms
Rear Wiper Cleanup Counter (0-7): 0,000
Speed Sensitive Wipe: Disabled
Small Washer Bottle: Disabled
Wireless:
AP5 Trunk Unlock: CAN
Airport Scenario Trunk set: No
AP1 Left Front: Smart Switch
AP2 Right Front: Smart Switch
AP3 Left Rear: Not Present
AP4 Right Rear: Not Present
Cust.Set.Menu 1:
Park Assist CSM Present: Feature 1 - 2 option
Park Assist Brake CSM Present: No
Park Assist Front Volume CSM Present: No
Park Assist Rear Volume CSM Present: Yes
Electric Power Steering CSM Present: Yes
Forward Collision Warning CSM Present: Not Present
Forward Collision Mitigation Braking CSM Present: No
Sound Horn with Remote Lock CSM Present: Feature 2 - 3 Option
Sound Horn with Remote Start CSM Present: Yes
Sound Horn with Remote Lower CSM Present: No
CHMSL Line CSM Present: No
Auto on Driver Comfort CSM Present: Not Present
Auxiliary Switches CSM Present: Not Present
Rear View Camera Gridlines CSM Present: Dynamic
Unit Set CSM Present: Yes
Power Accessory Delay CSM Present: Yes
Adaptive Front Light System CSM Present: No
Ambient Dimmer CSM Present: No
Tire Jack Mode CSM Present: No
Air Suspension Warning CSM Present: No
Automatic Aero Mode CSM Present: No
Auto High Beam CSM Present: No
Auto Park CSM Present: No
Blind Spot Alert CSM Present: Yes
Capacity Unit CSM Present: No
Clock Display CSM Present: No
Compass Calibration CSM Present: No
Compass Variance CSM Present: No
Consumption Unit CSM Present: Yes
Distance Unit CSM Present: Yes
Auto Door Lock CSM Present: No
Auto Door Unlock CSM Present: Yes
Daytime running lights CSM Present: Yes
Easy Exit Seat CSM Present: No
Auto Entry Exit Mode CSM Present: No
EPB Service Mode CSM Present: No
Flash Lamps with Lock CSM Present: Yes
Headlamp Drop CSM Present: No
Headlamp Off Delay CSM Present: Yes
Headlamps On with Wiper CSM Present: Yes
Hill Start Assist CSM Present: Yes
Illuminated Approach CSM Present: Yes
Lane Departure Torque CSM Present: No
Lane Departure Warning CSM Present: No
Flash Lights with Remote Lower CSM Present: No
Navigation Turn-by-Turn CSM Present: Yes
Passive Entry CSM Present: Yes
Performance Shift Enable CSM Present: No
Performance Shift RPM CSM Present: No
Power Liftgate Chime CSM Present: No
Power Unit Customer Settings Menu: No
Pressure Unit CSM Present: Yes
Power Take Off CSM Present: No
Rain Sensitive Wipers CSM Present: No
Rear Camera CSM Present: Yes
Cust.Set.Menu 2:
Configuration message CSM2 Status: Not allowed
Rear View Camera Delay CSM Present: Yes
RKE Linked to Memory CSM Present: No
RKE Unlock CSM Present: Yes
Speed unit CSM Present: Yes
Tilt Mirror In Reverse CSM Present: No
Torque Unit CSM Present: No
Trailer Selected CSM Present: No
Trailer Name CSM Present: No
Trailer Type CSM Present: No
Transport Mode CSM Present: No
US/Metric CSM Present: No
Wheel Alignment CSM Present: No
Fuel Saver CSM Present: No
Tempature Unit CSM Present: Yes
Auto Power Folding Mirrors CSM Present: No
Forward Collision Warning (FCW) Switch CSM Present: No
Cust.Prog.Features:
Sound Horn on Remote Start: Enabled
Flash Lamps on Lock: Enabled
Headlamps ON with Wipers: Enabled
Auto Wipers: Not enabled
Auto Lock: Enabled
Auto Unlock: Enabled
Delay Lock: Not enabled
Illuminated Approach Time (0-254 sec): 30,000 sec
Headlamp Delay Time (0-254 sec): 30,000 sec
Accessory Delay Time (0-65534 sec): 45,000 sec
Sound Horn On Lock Status: Chirp on 1st press
Daytime Running Lamps: Enabled
Auto High Beam: Not enabled
Door Alert Enable: Not enabled
One Press All Unlock Enable: Enabled
Auto Relock: Enabled
EC Mirror Auto-Dimming Enabled: Enabled
Remote Lowering Horn Enabled: Not enabled
Remote Lowering Lights Enabled: Not enabled
Ambient Dimmer Level (0-100%): 0,000 %
LIN Cust Prog Feat:
Rear View Camera Static Grid Lines Enabled: Disabled
Rear View Camera Dynamic Grid Lines Enabled: Enabled
Cabin Net:
RBSM Right Blind Spot Module: Enabled
BSS Blind-Spot Sensor/LBSS Left Blind-Spot Sensor: Enabled
BCM Body Interior Bus: Enabled
HSM Heated Seat Module: Not enabled
DDM Driver Door Module: Enabled
PDM Passenger Door Module: Enabled
DMRL Door Module Rear Left: Not enabled
DMRR Door Module Rear Right: Not enabled
HVAC Heat Ventillation Air Conditioner: Enabled
MSM Memory Seat Module: Not enabled
PLGM Power Liftgate Module: Not enabled
VTM Vehicle Tracking Module: Not enabled
PSDML Power Sliding Door Left: Not enabled
PSDMR Power Sliding Door Right: Not enabled
FSM Fold Stow Module: Not enabled
PTCM Power Top Control: Not enabled
RBC Regenerative Brakes Control: Not enabled
DTV Digital TV: Not enabled
Radio/TGW Telematic Gateway: Enabled
Clock: Not enabled
VSIM Vehicle System Interface: Not enabled
ITM Intrusion Module: Not enabled
AMP Amplifier: Enabled
EDM External Disc Module: Not enabled
HFM/CTM Hands-Free Module: Not enabled
ICS Integrated Center Stack: Enabled
VES2 Vehicle Entertainment 2nd Row: Not enabled
VES3 Vehicle Entertainment Last Row: Not enabled
CRSM Comfort Rear Seats Module: Not enabled
HVAC_R Rear Heat Ventillation Air Conditioner: Not enabled
P/T Chassis Net:
ACC Adaptive Cruise Control: Not enabled
ADCM Active Dumping Control: Not enabled
AHLM/AFLS Headlamp Leveling: Not enabled
ASCM Air Suspension Control Module: Not enabled
BCM (PT) Body Control Module: Enabled
DTCM Drive Train Control: Not enabled
ECM/PCM Powertrain Control: Enabled
EPS Electric Power Steering: Enabled
ESM Electronic Shift Module: Enabled
ABS/ESC: Enabled
EPB Electronic Parking Brake: Not enabled
RFH Radio Frequency Hub: Enabled
IPC Instrument Panel: Enabled
ACC/DASM Adaptive Cruise Control/Driver Assistance Module: Not enabled
FDCM Final Drive Control: Not enabled
EPPM Electronic Pedestrian Protection: Not enabled
ORC Occupant Restraint control: Enabled
PTS Parktronics: Enabled
RBT Driver: Not enabled
RBT Passenger: Not enabled
SCCM Steering Column Control: Enabled
ELSD Electronic Limited Slip Differential: Not enabled
TCM Transmission Control: Enabled
TPM Tire Pressure Control: Enabled
PASS (PT) Personal Assistance and Safety Services: Not enabled
AFLS Discharge lamps: Not enabled
ITBM/HWM Integrated Trailer Brake Module: Not enabled
OCM Occupant Classification Module: Not enabled
FFCM/HALF Front Facing Camera Module: Not enabled
ANC Active Noise Cancellation: Not enabled
Audio/Telemat Net:
AMP Amplifier: Not enabled
ICS Integrated Center Stack: Not enabled
PASS (A/T) Personal Assistance and Safety Services: Not enabled
SDARV Satellite Video Receiver: Not enabled
DVD Changer: Not enabled
HFM Hands Free Module: Not enabled
Hybrid LAN Net:
APM Accessory Power Module: Not enabled
TCM Transmission Control: Not enabled
BPCM Battery Pack Control: Not enabled
HCP Hybrid Control Processor: Not enabled
MCPA Motor Control Processor A: Not enabled
MCPB/ESC Motor Control Processor B: Not enabled
I have the same problem. I can turn off right rear turn lamp diagnostic but can't turn off left rear turn lamp. Do you have solution? Or only give ground to sense wire?
Solved.
I had to use CDA6. There I found option to disable left rear turn diagnose.
Thanks given by: ADAM1991
What is the name of this option?
(07-21-2025, 01:04 AM)cered Wrote: What is the name of this option?
hi
i need too... slove problem with alfa obd ?
Bartek
Alfa OBD has a bug.
You have to find
CBC Config I/O Usage-Left Rear Door Ajar Switch Signal Usage
in this option you can see diagnostic right front lamp but it is incorrect. This function is refering to rear left light.
Thanks given by: goosebartek
05-11-2026, 04:41 PM
02-03-2026, 01:06 PM
01-07-2026, 12:17 PM
