Carprog can't read Motorola MCU
HC912DG128. I've have Carprog clone few days and tried to read it via A10 adapter soldered to pads on board. It didn't worked. Carprog shows only 5 times attempt and nothing happens. Same with write. So i tried lifting BKGD pin (grey wire) from board. No result. I've also took MCU out of board and it didn't work too. To verify that my Carprog is good, i've also tried reading HC9S12 form i believe ford cluster that i had lying around but I dont know if its damaged or not, someone gave me this long ago. Same story, no read no write. So what I could do wrong? My Carprog failed or I have bad luck and both MCUs are damaged? I've got second BSI with HC912DG128 and no luck.
Can you please send a pic of your carprog pcb?
Do you or can you check if your carprog can r/w simple 93Cxx eep' s incircuit or out of the pcb?
Sent from my SM-J500F using Tapatalk
If my post helped in any way please give me a Thanks and Rep.
I will appreciate that. Thankyou
Thanks given by: dmd1337
Solved. Wire colours in adapters were messed up. Checked and works good. Thank you.
(09-13-2019, 08:17 PM)dmd1337 Wrote: Solved. Wire colours in adapters were messed up. Checked and works good. Thank you.
would you please elaborate on the solution?!?
How was it messed up, what are the right colours?
It might help others later on...
Cheers
It will help to others just IF others write in google "carprog a10 adapter" and look magic Wink
If i helped DONT click Thanx and DONT click reputation !!!
(01-05-2020, 07:46 PM)skyline-GTR Wrote: It will help to others just IF others write in google "carprog a10 adapter" and look magic Wink
The other thing I love about this forum is that you have to guess what other ppl meant due to their magic English Wink
Thanks given by: flyhighjdm , catala20032004
02-08-2020, 04:48 PM
02-08-2020, 12:53 AM
02-06-2020, 06:25 PM
01-17-2020, 01:52 PM
12-21-2019, 09:45 PM
