Checksum new e92, e98 etc
Friends, is there any calculator, or way to correct the checksum of these new delco gm modules?? I'm using the original io terminal, and it doesn't fix it, I'm getting stuck in these centers
Thanks given by: GreeX
I can do E92, so can universalpatcher I believe.. Post up an E98 and I can see if I have anything for it.
(12-28-2023, 01:46 AM)Tek1229 e98 does not work with universal patch, it does the calculation and corrects it but the car gives a power error and does not start Wrote: I can do E92, so can universalpatcher I believe..  Post up an E98 and I can see if I have anything for it.
I have a winols plugin for this block
NBT DTC Decoder official distributor
(12-28-2023, 03:21 AM)alexbez Wrote: I have a winols plugin for this block
there is no winols plugin supporting e98
So your all set with the E92 then?? Just stuck on E98 bin's??  Post one up here and I'll take a look..
There is, of course only for original winols.  OLS293 - Denso.
(12-28-2023, 12:43 AM)Iannakano Wrote: Friends, is there any calculator, or way to correct the checksum of these new delco gm modules?? I'm using the original io terminal, and it doesn't fix it, I'm getting stuck in these centers
Im also using IoT for these. Possible to correct CS without winols. For old e98 LSuite works, for newer LSuite not works, but there are another software that can help Smile
I need to fix the checksum of a GM E92, I'm trying to load a modified file with removed dtc's, but my tool doesn't calculate the checksum on this ecu, can someone help me please, of course I'm not looking for something free, tell me internally how much you charge me for that solution. Thank you very much
Here is the original Flash file and the modified one.
Ori and dtc off.rar
15
2.43 MB
(11-04-2024, 08:04 PM)dctruck_dc Wrote: I need to fix the checksum of a GM E92, I'm trying to load a modified file with removed dtc's, but my tool doesn't calculate the checksum on this ecu, can someone help me please, of course I'm not looking for something free, tell me internally how much you charge me for that solution. Thank you very much
Hello, attached your file with checksum fixed.
Pass in your PM after rep+thx
[Image: logo_t10.png]
          Original Developer
Thanks given by: dctruck_dc
05-06-2026, 12:59 PM
04-07-2026, 08:34 PM
Opel
04-01-2026, 12:16 AM
