0
Thanks Given: 2
Thanks Received: 0 (0 Posts)
Hello! I'm trying to find an interesting problem. The engine starts and runs good when it cold until it is turned off after warming up. Experimetally found a way to start the enigine - spray fuel into the intake manifold with the pedal pressed, it starts and then runs normally. It looks like there is some kind of startup prohibition, according to the engine and fuel system diagnostics, there are no errors. There is pressure in the fuel rail, the fuel pump relay turns on.
This vehicle is from USA, after an accident. There are only 2 errors - about airbag and hood ajar circuit (B3006-01, B3006-02, B3006-04). I've checked the hood switch and it works properly. May it be the problem with autostart system ?
2,375
Thanks Given: 400
Thanks Received: 5812 (3906 Posts)
5,427
13
Check the coolant sensor.
If you do not click thanks and rate for my free help, you will be put on ignore. No help next time.
Do NOT PM me for help, post it in the forum!
0
Thanks Given: 2
ECT sensor seems to be good. The temperature rises normally. After the engine stops, the sensor continues to show the true temperature, but the engine no longer starts untill it cools down
670
Thanks Given: 224
Thanks Received: 1408 (399 Posts)
1,122
193
(04-29-2024, 06:33 PM)Motorlomo Wrote: ECT sensor seems to be good. The temperature rises normally. After the engine stops, the sensor continues to show the true temperature, but the engine no longer starts untill it cools down
Crankshaft sensor, that is symptom when it fails
