To obtain your registration code or your not able to recover your MHH account, kindly contact [email protected]
MHH is in-compatible with all Internet explorer (IE) versions, but good with MS edge. Best viewed with chrome!
  • 73 Vote(s) - 2.93 Average
China VCM's guide
Hi guys I've done some small research about China Town VCM's and want to share my findings with you.
This picture is original Main Dealer Rotunda VCM
.jpg
3,105
424.02 KB
As you can see all circuits are gold plated and good quality components, metal casing with no production date stickers etc. on it.
These are most popular VCM clones you can get on china market at the moment:
Type A
.jpg
2,553
439.23 KB
.jpg
2,856
119.01 KB
Top Quality Ford IDS or Super Ford VCM (dual PCB)
This kinds Ford VCM has the same PCB Design with the original,but has Tin/Lead plated printed circuit board and different components(capacitors, some chips).Comes with metal casing with production date stickers.
It is the Top quality clone Ford VCM from http://www.adkautoscan.com
can be used on the original software of Ford VCM Ford IDS (need crack), comes with IDS V75, Jaguar & Land Rover: V128
Suitable for programming on all makes,DPF regeneration/replacement, key coding and relatively safe.Should be no problem with firmware update.
Type B
.jpg
2,014
96.06 KB
Good Quality Ford IDS (dual PCB)
The PCB of this kind Ford VCM is little different design with the original.Tin/Lead plated printed circuit board,metal casing, production date stickers.
Can support Jaguar & Land Rover, and can also be used on the original software of Ford IDS (need crack) comes with V75-78, Jaguar & Land Rover: V128
Suitable for programming on all makes, DPF regeneration/replacement, key coding and relatively safe.
Type C
.jpg
1,266
812.89 KB
.jpg
692
772.42 KB
.jpg
711
571.71 KB
Medium Quality FLY version with red relays (dual PCB)
The PCB of this kind Ford VCM is different with the original.Can't be used with the original software of Ford VCM.Metal or plastic casing with production date stickers.
Works only with modified FLY soft and FLY crack(_VCM.bfc 617KB for Ford IDS and MAZDA, _VCM.bfc 1907KB for JLR ).Comes with software version: IDS V80 ,JLR V130,MAZDA V79 but most likely they are modified old versions (V75,V128???) not confirmed yet Wink
Comes with FLY Swich as well so all makes can be installed on same system, not recommended for Ford and Mazda(system conflicts).
Ford IDS, Mazda
Not suitable for module programming (can corrupt/lock PCM,TCM), may work with other modules but you using it on your own risk Smile should work with DPF,key coding,injector coding.They have a habit of re-flashing PCM when you choose Self Test option.
JLR
Need more info about programming and coding possibility???
Type C
.jpg
1,056
27.55 KB
.jpg
781
28.52 KB
.jpg
812
27.63 KB
Low quality copy with SONY chip inside (dual PCB)
PCB different than original Rotunda VCM.Comes with V75, V128 original Ford VCM soft (need crack). Metal casing with prod. date stickers.
Not suitable for module programming,not safe in use, not recommended!!!
ALL THE REST!!!
.jpg
935
7.57 KB
.jpg
991
69.69 KB
.jpg
829
49.03 KB
Dual red PCB,Single red PCB's, Single green PCB's etc. just forget about and stay away from that scrap!!!
And one more thing, USB<->VCM connection cable must have small "Real" chip inside for ethernet connection.
.jpg
618
34.76 KB
ALL COMMENTS/CORRECTIONS, YOUR OWN EXPERIENCE WITH DIFFERENT VCM's AND SOFT ARE MORE THAN WELCOME!?
Ps. If you find this thread usefull please press
.gif
9,816
855 bytes
button to motivate me even moreFing32
Just like to add that if you have communication problems, check the soldering in the USB modem (the one with REAL chip) mine was loosing communication and I found problem with soldering there.
roth
Image and video hosting by TinyPic Roth
Thanks given by: Dansen , coriducu , gerberauto
And sometimes this cable has corrupted content inside the EEprom. Cheers!
CMD_VCM_Ford_Interface_93LC46A_USB_Ehternet.rar
1,220
228 bytes
[Image: signature.png]
hello friend
Do you can show me one that ids of china that set the Pats in position for trucks
sorry to spam forum
but is this one any good
cheers
.jpg
923
197.4 KB
cheers all
Thanks for the pictures. I'm thinking of getting the one from ADK, but have a couple questions maybe u know the answers Smile
- Can the firmware ever be updated on it? I have the original GNA600 fro Honda and seems theres a new update everytime a new version came out.
- Can we use the V80 or V81 (or newer) with it?
thanks
(11-11-2012, 11:44 PM)paulo silas Wrote: hello friend
Sorry but I've never use it on trucks, try to search the forum, or just go for good quality one.
(11-12-2012, 10:23 PM)iDIDNTdoIT Wrote: Thanks for the pictures. I'm thinking of getting the one from ADK, but have a couple questions maybe u know the answers Smile
thanks
As I've said in the first post, update is available for good quality units.But always ask before you order anything from any china shop.
I've seen licence for V80(Ford) somewhere on this forum, V81 as far as I know is still not cracked.
Thanks given by: gerberauto
Hello, my VCI does not work after installation. after tucked into the outlet only OBD2 flashing red and green LEDs. Same time, does anyone know what?
04-18-2019, 04:46 AM
02-16-2019, 01:44 AM
09-15-2018, 11:16 AM
07-08-2018, 08:06 AM
Ford
07-07-2018, 12:42 AM
