Chrysler Jeep software
Hello i am looking for a good ecu coding tool on cars mainly chrysler it comes with bcm coding
chrysler pacyfica 2016 2017.
Can you recommend something?
micropod2 with subscription
If my post was helpful in anyway, don't forget to press "Reputation+ and +Thanks"
(01-14-2020, 10:53 PM)ziomal4340 Wrote: Hello i am looking for a good ecu coding tool on cars mainly chrysler it comes with bcm coding
If cars are not superior at 2017 you can simply download WiTech software from here and buy a Clone VCpod
here one of the link on this forum
https://mhhauto.com/Thread-wiTECH-Activa...ght=witech
I use Appcar DiagFCA ..... coding , adaptapion offline . Internet needed only for 5 min when U reading new car ( downloading files for modules ).
https://appcar-diagfca.com/en/
I would also suggest witech 17.04.27, a clone micropod 2 and contacting DieTRih to set it up so you can use techauthority with witech 17 (link below). This would be the only way I can think of outside of a witech 2 subscription that you would: be able to access the BCM, download flash files for it and flash it, then access the auburn hills FCA servers to "restore vehicle configuration" when you were done.
I'm happy to sell you CDA 6 but I don't think that is the best solution to your problem.
https://mhhauto.com/Thread-wiTECH-Activa...#pid951539
Micropod 2 firmware downgrade utility & SN changer, Chrysler Diagnostic Application CDA 6.7, CDA 6.13, FCA Flash File downloader, 38GB factory docs. Real hardware: Micropod 2 for WiTech 2, VCI pod, Starmobile, Starscan, DRB 3. Message for details
Chrysler
06-20-2020, 10:02 AM
06-16-2020, 03:25 PM
06-07-2020, 09:37 PM
05-22-2020, 03:51 AM
Dodge
05-22-2020, 03:17 AM
