Citroen C3 EDC16 Info Display
I had EGR and some DTC off for an EDC16 Citroen C3 , but the central info display still shows anti-polution, airbag, etc problems , etc.
(no DTC stored in ECU , no checklight)
https://youtu.be/DeK41388zRQ
is there a way to delete / deactivate the info in this display and retain only time / date / outside temp?
many thanks
set BSI on without dpf with launch or lexia
Thanks given by: euromod
Thanks mate, but this car has no dpf
try disconnect egr valve
Is disconnected mate. I even cut out the can wires to display and still shows the errors...
send ori and off
Audi
06-13-2026, 09:16 PM
06-07-2026, 06:53 AM
