Thanks Given: 119
Thanks Received: 45 (25 Posts)
632
258
Need help DTC P0011 off
Original WinOLS user, Original Flex Master, Original VCDS, Original X17 & Flex Master and Odis
238
Thanks Given: 83
Thanks Received: 457 (344 Posts)
797
78
post normal flash read. not int flash you cant correct checksum with full backup file
Please use THANKS and REPUTATION if my post was helpfull!!
18
Thanks Given: 54
Thanks Received: 140 (107 Posts)
594
P0011 Inlet camshaft position fault
Better change the inlet valve ... not remove the DTC.
The removing DTC is not repairing procedure.
BR
