  • 6 Vote(s) - 3.83 Average
Clio 1.4 16V Sirius 34 immo off.
friend ask me to remove immo from this car. He send me numbers, it's Sirius 34 S118301109A, probably it's with CAN so I guess I need an emulator, right?
Second problem is unfortunately I can't desolder this 29F400 (or 200). Is there any possibility to read it using KTAG? MPPS v16? Galletto v54?
I prefer KTAG (cause didn't yet reworked galletto).
Regards!
If helped hit "+Thanks" and "+Reputation" button Smile.
If wrote something interesting also click on "+Thanks" Smile.
Have a nice day.
I have found something about reading it. Just please tell me if my thinking is good. I haven't been using v54 yet.
For boot mode just put grey wire on pin 28 (Just like I painted it) and that is all or I need also put there any ground? Just paint the good version for me if I think bad. Is also additional +12v needed? Or galletto will send it itself?
sir34.zip
File Type: .zip
Downloaded: 26 times
[Image: UDXH0Umh.jpg]
BTW. I can't find this scheme like on left in my galletto's soft, where to find it because I see manuals for bdm, boot tricore but not this siemens? (for the future)
Have a nice day.
29F400 is plug in socket, you can remove off without soldering.
CAN system, faster is repair or recode new key. Also car keep all function.
No THANKS + REPUTATION, no HELP!!!
Thanks given by: razor1199
#4
(10-12-2017, 04:09 PM)perso69man Wrote: 29F400 is plug in socket, you can remove off without soldering.
Could you exactly tell me what functions I will loose? :-(
I will see if 29F400 will be on socket if I open ECU, at this moment I don't have it, sometimes flash was soldered.
Have a nice day.
Some people report that missing speed or someyhing like that in dash.
And what is the problem with car? If immo light flashing, there are 3 case:
Key, Coil around barrel or UCH.`
Also if you have no experience with ECU, don't touch it or you can add new problem to car.
#6
I can do sirius 34 immo off,tested,you can pm me if you want.
(10-12-2017, 09:23 PM)perso69man Wrote: Some people report that missing speed or someyhing like that in dash.
Diode shine continuously. I've done sagem s2000rpm using julie emulator without cutting can lines, then dashboard was working well.
Have a nice day.
  Need Immo Off - Iaw 48P2-80 Saxo VTS 16v darioz90 11 219 3 hours ago
Last Post: josph
Renult immo off Renault Clio II - IAW 5NR2.C2 valentino_val 2 51 5 hours ago
Last Post: Le-Mans
Hyundai engine driver 2.0 16v Michal72212 0 47 09-21-2018, 02:13 AM
Last Post: Michal72212
Renult airbag clio 4 alama28 2 128 09-20-2018, 12:57 PM
Last Post: alama28
  Siemens Sirius 32n file ori akiminem 8 134 09-19-2018, 11:13 AM
Last Post: akiminem
