Hello everyone, I kindly need to clarify two doubts:
1 – I have a Corsa D with a completely water-damaged ECU. I’ve found another ECU in good condition, but I need to know if they’re compatible, since I noticed some of the numbers are different.
2 – If the replacement ECU is compatible, is it enough to swap the EEPROM? Or do I need to retrieve the PIN from the new ECU to reset and reprogram it to the car?
Thanks in advance for your help!
I’m attaching photos of the original (damaged) ECU and the replacement I found.
