I have a interesting problem, corsa D 2012 a13dte with no power to IPC, Info Display and Radio. If i apply 12v directly to fuse 1 and/ or fuse 8(interior fuse box) everything works.
Is there an hidden fuse that powers fuse 1 and fuse 8 of the bcm? I already changed the bcm with no result
Maybe someone has an wiring diagram
Thank you all
Thank you all
Thanks given by: KIR73
