Corsa D Bsi (Delphi)
[Image: opel_delphi_BCM.jpg]Hello >I have the pinout for VVDI to read the MCU, Do I need to remove the Eeprom to read it .
I presume it is the Eeprom next to the word Reset
David
Pinout is only for processor NEC to read not for eeprom.
(01-31-2025, 10:47 PM)KIR73 Wrote: Pinout is only for processor NEC to read not for eeprom.
[Image: 54300215261_c544bd3df3.jpg]
Would anyone have a pinout for this board I am using vvdi prog and am getting frequency error
Thank you
For Pin you need combination of both Nec and eeprom
Press REP + Thanks if i helped youTup1087
Thanks given by: bighomer46
Its the connections for the programmer i cant find for my board
I have a GM 13265078 Delphi BCM. I want to replace it with the 13265077 BCM in my 2008 Corsa D, but I don't know the pin code of 13265078. Can I read the flash from the NEC processor with Carprog?
Fileservice = On demand! Master & Slaves
06-12-2026, 06:27 PM
Opel
05-30-2026, 08:29 PM
