  • 38 Vote(s) - 3.03 Average
Corsa Easytronic touchpoint adaptation "no programming approval found"
Hello all, I'm looking for some advice.
I was asked to visit a user after they had their 2002 Corsa Easytronic ECU repaired, they were having problems with the transmission when pulling away from junctions like the clutch not engaging properly.
So I figured the Easytronic touchpoint adaptation needs to be re-learned.
I've tried to do this today with my laptop using AVDI & Tech2Win (which I use all the time and never have any issues) I get something close to the following message after Tech2 goes though "checking conditions"
Quote:No programming approval found!
Please get programming approval from TIS
I don't have a Tis2Web subscription, I'm using GlobalTIS 32B, do I need to install TIS2000 on my laptop? Is this all I need to resolve this?
Thanks!
Muzza!
Never mind I sorted it with advice from another forum.
You leave Tech2Win open then launch Security Access from GlobalTIS and perform download for Tech2, it will then grant additional security licence for the required programming.
any idea on how to repair the ecu??
(03-29-2014, 06:45 PM)Muzza80 Wrote: No importa, lo solucioné con los consejos de otro foro.
Deja Tech2Win abierto, luego inicia Security Access desde GlobalTIS y realiza la descarga para Tech2; luego otorgará una licencia de seguridad adicional para la programación requerida.
Buenas tardes
Como lo solucionaste en tu caso por favor? tengo el mismo problema
gracias
Hi! with OP-COM you can do touch adapatations easy procedure. For Corsa (South America) need to bridge pin 7 and 8 of OPCOM interface. If you need working flash i have a couple (29f400 or 29f200 and 24c16 eeprom).
06-12-2026, 06:27 PM
Opel
05-30-2026, 08:29 PM
