22
Thanks Given: 687
Thanks Received: 158 (134 Posts)
1,811
705
07-14-2019, 11:18 PM
Guys, I sent the clutch actuator for repairs at ecu testing. Whilst trying to calibrate the clutch endpoint, I hit the gearbox learn option. Now car does not start and have error p1735 gearbox parameters not learned. Now car doesn't start and I have the F. Is this something dealer can fix, or do I need to resend unit for fixing? Please advise.
Thanks.
599
Thanks Given: 69
Thanks Received: 1106 (26 Posts)
64
14
(07-14-2019, 11:18 PM)ryn079 Wrote: Guys, I sent the clutch actuator for repairs at ecu testing. Whilst trying to calibrate the clutch endpoint, I hit the gearbox learn option. Now car does not start and have error p1735 gearbox parameters not learned. Now car doesn't start and I have the F. Is this something dealer can fix, or do I need to resend unit for fixing? Please advise.
Thanks.
ryn079. When I get this dtc I can only resolve it by opening the MTA module (aks) and resetting it to eeprom 24c16. I record a reset file and then just do the (kiss point) clutch adjustment. I never make the gear adjustments, otherwise it generates this fault code and the scanner does not let it go out
If I helped and you like it, please click +1 GIVE REPUTATION and +1THANKS
79
Thanks Given: 273
Thanks Received: 517 (403 Posts)
1,331
Dealer tool does exactly what opcom does. Resetting eeprom is stupid. Wrong parameters would be learned, bad operation of the gears. Lift the front wheels and try again. Record video post on youtube so we can also see.
Thanks Given: 58
Thanks Received: 54 (26 Posts)
128
17
07-16-2019, 06:20 PM
Try With Tech2 Mdi programmer!!!
Thanks Given: 1
Thanks Received: 6 (4 Posts)
easy and uncomplicated.
Solder out the 24C16. Read it out and just send me the bin file.
I'll change it for you. Then just write back and it's good.
All learning values are retained.
Kind regards
Jörg PS:
send me the file as a PM
Thanks Given: 74
Thanks Received: 41 (11 Posts)
102
55
Can you please send me the eeprom file because I have the same problem?
Thanks Given: 1
10-19-2020, 10:03 PM
(This post was last modified: 10-20-2020, 11:10 AM by JPtronic.)
Benötige Ihre Fahrgestellnummer.
Oder Sie senden mir Ihre bin Datei vom 24C16.
mfg
Thanks Given: 74
102
55
thanks a lot for your interested and reply.
the car vin number is W0L0ZCF6981113154 Vectra-C the orginal eeprom file is erased by mistake
