  • 1 Vote(s) - 5 Average
Corsa c ecu replace
10-12-2017, 09:54 AM
Corsa c ecu replace
Hi
I need change ecu 1.7 diesel corsa c y17dt
I installed donor reseted it with avdi
The use opcom cl go to immo2
Enter pincode
Programm ecu to immo
Message appear all finished ok
But immo light is flashing car not starts.
P1615 p1616 is stored.
Put back ori ecu car starts
Ecu has not exactly same pn
Can someone help
10-12-2017, 10:07 AM
RE: Corsa c ecu replace
dont you need to reset all modules
10-12-2017, 10:08 AM
(10-12-2017 09:54 AM)chris2011 Wrote:  Hi
Enter pincode
Can someone help
hi,
you have to reset immo to and cluster also then programm again incl.keys
if it helps you sends thanks
 Thanks given by: chris2011
10-12-2017, 11:04 AM
you need reset and reprogram ecu, body and cluster. no need reset immo.
1 step go to ecu reset and program it with immo. 2 step go to body and reset/program it. 3 step same to cluster.
clear all dtc's.
10-12-2017, 07:14 PM
ah ok i did not make the BCM
in immo2 options i just saw option replace immo and engine ecu
  Opel Corsa d edc17c59 how to read? Chris AGR 3 142 09-17-2018 08:32 PM
Last Post: vaggelis00
Opel Corsa D speedo and mileage help needed luk204 4 180 09-17-2018 04:20 AM
Last Post: rch11
Opel Bosch edc17c59 (Opel Corsa d) FULL PINOUT Chris AGR 0 99 09-14-2018 08:01 AM
Last Post: Chris AGR
  OPEL CORSA C PIN FROM BCM makura 1 96 09-14-2018 02:51 AM
Last Post: Tawe
  Pin Code Corsa D dash kos9979 11 238 09-13-2018 10:56 AM
Last Post: CODEBAX
