  • 26 Vote(s) - 3.19 Average
Cummins INCAL 08.2012
[Image: b5fc1a16bc61e30ff8b0d7b555ee6026.jpeg]
Cummins INCAL 08.2012 | 7.26 GB
The INCAL is a set of 4 cds which contain the latest revision of ECM Calibrations. They are released and sent out monthly to INCAL Subscribers. Please contact your Cummins distributor for more information.
In cal cd's are Cummins ecm calibration files cd's, comes in a set of four cd. One a customer wants to upgrade horse power with in the same engine cpl or range, thru insite or with insite pro program and calibration password he is able to calibrate an ecm that has an existent or previous calibration in it. Let say I have a Cummins engine N14 cpl 1574 370 horse power thru insite pro with calibration files(in cal cd's) I superseded or find for cpl 1574 the higher horse power available in the in cal cd's and reprogram ecm with it, using one calibration password count and the proper Cummins inline 5 adapter. Cd one may be for ism or isx, cd 3 may be for N14 or M11, and so on.
Cummins INCAL can be used with Cummins Insite software :
Insite Calibration Library (INCAL) April 2010 contains flash files for ECUs of the following engines:
480C-E
B5.9G
C Gas/B Gas Plus
C8.3G
Celect
Celect Plus
Celect Plus Industrial
CENSE
Centinel
CENTRY
Gas Cense - CM850
Gas Compression GTA, KTA
ISB
ISB - CM2150D
ISB Daimler Chrysler
ISB-CM850
ISBe (4 and 6 Cylinder)
ISBe4 (4 and 6 cylinder)
ISC - CM2150D
ISC/ISL
ISC/Transit Bus ISL8.3 - CM850
ISDe - CM2150C
ISFe3 - CM2220
ISL - CM2150D
ISL G - CM2180A
ISL8.9 - CM850
ISLe - CM2150C
ISLe4 (6 cylinder)
ISM
ISM - CM870
ISM - CM875
ISM - CM876
ISM-Fuel Control Module -CM570
ISX - CM871
L Gas Plus
L10G
PIM
QSB3.3 - CM2150C/D
QSB4.5/5.9/6.7 - CM850
QSB5.9/44, 5.9/30, 4.5/30, 3.9/30
QSB5/7 - CM850 - Power Gen
QSC8.3 - CM850
QSC8.3QSL9
QSK 19/23/45/60/78
QSK 19G/45G/60G, QSV81/91 - MCM700
QSK 19G/45G/60G, QSV81/91 - SSM558
QSK19 - CM850/CM2150D - MCRS
QSK19 - CM850/CM2150D - Power Gen
QSK38 - CM850/CM2150D - MCRS - Primary
QSK38 - CM850/CM2150D - MCRS - Secondary
QSK38 - CM850/CM2150D - Power Gen - Primary
QSK38 - CM850/CM2150D - Power Gen - Secondary
QSK50/60 - CM850/CM2150D - MCRS - Primary
QSK50/60 - CM850/CM2150D - MCRS - Secondary
QSK50/60 - CM850/CM2150D - Power Gen - Primary
QSK50/60 - CM850/CM2150D - Power Gen - Secondary
QSL9 - CM850
QSL9 - CM850 - Power Gen
QSM 11 - CM876 - Power Gen
QSM11
QST30
QSX15
Signature/ISX
Signature/ISX - CM870
.txt
Download Links.txt
332
1.98 KB
How long do these CD's last before they expire?....When will the next be out?
there is a new one every month, at my work we dont use cd we just download right of the site for the latest files and i dont believe cds expire u just wont have the latest update
I think every versions expires after 3 mounth...
anyone have the cal .. for the cummins n14 and isx ? all the links for incal suck thanks ..
(10-26-2012, 10:39 AM)sp33d Wrote: anyone have the cal .. for the cummins n14 and isx ? all the links for incal suck thanks ..
Looking fo Incal also thank you
liks off,
can return the new?
thank you
09-08-2018, 02:16 PM
03-23-2018, 06:02 PM
08-17-2017, 05:36 AM
07-17-2017, 01:15 PM
06-05-2017, 06:07 PM
