  • 6 Vote(s) - 2 Average
Cummins cal file
Is there any 500 or 550hp 1850ft/lb cal files for this engine?
cpl#8520 engine sn #79041295
Sent from my HTC One using Tapatalk
(05-30-2018, 11:10 PM)ajala Wrote: Is there any 500 or 550hp 1850ft/lb cal files for this engine?
Egr off or on?
Long live MHHAUTO. COMTup
Thanks given by: ajala
Egr on
Egr off or on?
(05-31-2018, 05:47 AM)ajala Wrote: Egr on
Egr off or on?
This is a 400hp engine from birth 550 is 30% over
Use cpl8519 475/1850 I put couple years ago in couple 8520 still runs strong,i don't see any side effect.
Sent from my SM-G955U1 using Tapatalk
I don't recommend jumping CPL's but I've heard of lots of people going from 8520 to 8519. I also have checked and cant find any differences. Here's one for 8519 550/1850 packed for 7.6
.txt
New Text Document.txt
24
50 bytes
(05-31-2018, 06:14 AM)silnoreki Wrote: Use cpl8519 475/1850 I put couple years ago in couple 8520 still runs strong,i don't see any side effect.
I was wondering if jumping cpl was a bad idea
Thank you very much
(05-31-2018, 06:42 AM)jbweld Wrote: I don't recommend jumping CPL's but I've heard of lots of people going from 8520 to 8519. I also have checked and cant find any differences. Here's one for 8519 550/1850 packed for 7.6
Thank you very much
Yes!!!!! different parts
Insite  8xxx Fleet Counts & Zapits
DDDL 8.09
Jpro 2019 2018
CAT ET 2019A
G̷h̷O̴s̴T̴m̷A̶n̸
Thank you very much
What parts specifically? I've been told by a friend at cummins that they will even use a different cpl on two identical engines just to separate calibrations and little things like that. But also can't believe everything one is told.
Thanks given by: lewap
7 hours ago
AA+MHH
07-09-2019, 07:36 PM
07-01-2019, 05:27 PM
06-24-2019, 07:40 PM
06-16-2019, 08:31 AM
