90
Thanks Given: 519
Thanks Received: 565 (86 Posts)
158
11
08-13-2016, 07:34 PM
(This post was last modified: 09-13-2016, 02:49 PM by DieTRih.)
DAS 09/2014
I tried my best to make it work but it is just not working. I always get same like these messages:
Even if I continued it will not do the programming.
I tried DieTRih Offline Fix from
HERE
I also tried JJD image from
HERE but non of them worked for me.
I have an old working OFFLINE Programming but it is 11/2012 and 01/2011 which are too old versions.
I am trying to program the g7 transmission. Any idea?
Master Computer Engineer, Microsoft Certified Educator/Trainer/IT Professional, Systems Engineer/Expert
349
Thanks Given: 251
Thanks Received: 1235 (315 Posts)
665
12
Use.. Vediamo or DTS.
Xentry&DTS with eCOM&VCI support
DTS 9.04.16 SUPPORT
90
Thanks Given: 519
158
11
08-13-2016, 10:46 PM
(08-13-2016, 10:16 PM)carlo Wrote: Use.. Vediamo or DTS.
I am neither familiar with Vediamo nor DTS.
340
Thanks Given: 119
Thanks Received: 2494 (1232 Posts)
2,415
18
You really think 221=171 g7transmission=CGW?
- SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
- HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
2,095
Thanks Given: 14574
6,536
46
What are you trying to do? Put a 221 CGW in a 171?
90
Thanks Given: 519
158
11
08-14-2016, 06:16 AM
(This post was last modified: 08-14-2016, 06:18 AM by zcc.)
(08-14-2016, 04:08 AM)Rocinante Wrote: What are you trying to do? Put a 221 CGW in a 171?
I don't know. I just want to program ECU's offline.
58
Thanks Given: 593
Thanks Received: 501 (216 Posts)
745
133
(08-14-2016, 06:16 AM)zcc Wrote: (08-14-2016, 04:08 AM)Rocinante Wrote: What are you trying to do? Put a 221 CGW in a 171?
Are you just trying to update software to a current version with the intention of fixing potential bugs?
I am not a robot. I can identify crosswalks, busses, cars, traffic lights, and mountain ranges.
90
Thanks Given: 519
158
11
(08-14-2016, 07:27 AM)e500 Wrote: (08-14-2016, 06:16 AM)zcc Wrote: (08-14-2016, 04:08 AM)Rocinante Wrote: What are you trying to do? Put a 221 CGW in a 171?
Yes you are right.
The problem is solved. It was a faulty 221.
276
Thanks Given: 307
Thanks Received: 550 (127 Posts)
487
60
As carlo said, you can use Vediamo to recode and reflash used modules .you cant reflash other module belong to other car with other VIN inside by DAS !
