  • 20 Vote(s) - 2.7 Average
DAS - Xentry (5-6.2015) Error Help -- Inconsistent fullupdate
Hello, everyone. I need help:
anyone have any ideas on how to solve the "inconsistent fullupdate issue...", error showed in the attached picture.
I used the fixes from Mr. DieTRih. And I followed the right install instructions.
But when I installed the DVD1, the error pops up.
Tried more than 10 times, always get the same error there.
Best Regards,
rrrqkqy
Hello ... you haven't done the necessary changes in the DVD Iso file. Replace all attached fixes and installation will goCall
Thanks given by: EN1GM4 , jacktrans
Not sure what you have already done but you could try to delete the registry entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Xentry
and try installation again.
Thanks given by: Yudi , Rocinante
use my step..
format your drive e:\ Wis
delete setup.ERR at c:\
restart pc
start again dvd1
regards,
Note : already tested by my machine and another member Big Grin
result..
http://mhhauto.com/Thread-MB-DAS-Xentry-...#pid453241
[Image: signaturemhhauto.gif]
(06-02-2015, 07:22 PM)rrrqkqy Wrote: Hello, everyone. I need help:
Becose missing some files.. JUST START again setup from 1 dvd.
Xentry&DTS with eCOM&VCI support
DTS 9.04.16 SUPPORT
Thanks given by: genito1979
You Read all the word Mr.Carlo...?
He Say "when I installed the DVD1, the error pops up.
Tried more than 10 times, always get the same error there."
why you suggest to install Dvd 1 again and again? try 100times? before doing anythings?
Regards,
Thanks given by: graphix , ToMiBoY , rrrqkqy , Rocinante
Regards,
Dear Yudi and all,
Sorry for my late reply and Thanks a lot for all your reply and help.
But I still cannot get rid out of this error.
I did try something before I re-install, I just think maybe something wrong I did, so I try to use different inx files from different user, try to format again, try to re-install OS, original EN XP Sp3 OS....
maybe the problem cause I cannot install .NET 3.5 SP1, "Microsoft. NET Framwork 3.5 SP1 has encountered a problem during setup." so I installed .NET framwork 4.0. Not sure if this is the problem. Otherwise, I really have no idea what is wrong with me? Or maybe I didn't format C drive, but it is NTFS system file format already, or ....
Best Regards,
rrrqkqy
PM me your teamviewer ID, i will repair it only 5-10 minutes..
regards,
Thanks given by: rrrqkqy , ToMiBoY , Rocinante , genito1979 , workshop369
Regards,
Dear Yudi and all,
I have the same problem this error
Inconsistent Full update
I try many times run the software again but still having the same error
I format the laptop 5 times and install again the software still the same error pop up on the screen
any body have this problem before please help.
I have the same problem with this error
have any idea how to solve this problem
please help.
