  • 25 Vote(s) - 3.08 Average
DDDL 6.47 changing parameter
Hello all , i need to change pulse / rev with DDDL6.47 , and when i write the password 0000 , and push transmit it take the password , but the case are all grey , and i can not change anything ?
i do something wrong ? , why the case are grey and cannot write new value ?
thanks in advance
regards
christian
(07-09-2015, 04:57 PM)sunsation288 Wrote: Hello all , i need to change pulse / rev with DDDL6.47 , and when i write the password 0000 , and push transmit it take the password , but the case are all grey , and i can not change anything ?
thanks in advance
regards
christian
The only thing I can think of is if its a locked out parameter or the anti tamper mayb is turned on I don't know if this will even work... never seen it before but just something I thought about. I think you can change the locked out parameters maybe... not sure on that.
Thanks given by: sunsation288
i look for the anti tamper
[Image: anti%20temper_zpsmrzlt2rx.png]
[Image: sending%20password_zps0zcebplm.png]
[Image: speed%20%20grayed_zpszkl1totz.png]
Thanks given by: wraytechs , Morton03
thanks in advance
regards
christian
have you checked in the lock out tab and made sure that its not locked out?
Just came across this thread while searching the same problem. Had to set the cruise and top speed limits. Did two 2009 Freightliners with series 60 engines. Both trucks needed four zeros for the parameter change code. So 0000 was the password that worked on both.
