DPF VOLVO S80 2.4D D5
Hi All
Need your help.
VOLVO S80 2.4D D5 2008. 0281012765
I tried to remove DPF with ADS, but not work.
Somebody can help correctly remove DPF.
0281012765_10375102650R.rar
11
69.73 KB
(08-04-2019, 07:50 PM)Newtec Wrote: Hi All
Need your help.
I can, attach ori pls
Chiptuning DynoTested
VAG Online Access
PCR2.1 Full Clone - Edc17 Full clone
[Image: S.png] CLICK TO ADD ON SKYPE
Thanks given by: Newtec
Need your help.
attached
thank you
Need your help.
Dpf OFF
Related Dtc OFF
Tested Wink
VAG Online Access
Need your help.
Dpf OFF
Related Dtc OFF
Tested Wink
Need your help.
Dpf OFF
Related Dtc OFF
Tested Wink
The car starts, in the beginning there are no errors.
On the road, it was without power, and the errors appeared:
P250A,  P0299,  U0322
and in ECM(BSI): U0301
Please help
Need your help.
Dpf OFF
Related Dtc OFF
Tested Wink
Need your help.
Dpf OFF
Related Dtc OFF
Tested Wink
P250A,  P0299,  U0322
Please help
Attached Fix Wink
VAG Online Access
Need your help.
Dpf OFF
Related Dtc OFF
Tested Wink
Need your help.
Dpf OFF
Related Dtc OFF
Tested Wink
P250A,  P0299,  U0322
Please help
Attached Fix Wink
The DTCs  P250A , P0299 , have disappeared, but the car is still unpowered, it seems to have no turbo
You should first repair your car.
P0299 - Turbocharger (TC)/supercharger (SC) – low boost
P250A - Engine Oil Level Sensor Circuit
If you have P0299 - your car will be unpowered.
Thanks given by: Bogdan Beb , Edc17tricore , teme69 , Newtec
Volvo
01-12-2020, 06:34 PM
Volvo
10-31-2019, 02:54 AM
09-28-2019, 11:52 AM
08-29-2019, 02:01 PM
07-09-2019, 04:22 PM
