DPS programming issue
I need to remove TPMS from opel insignia, 2010, with red display in IPC. I used SPS to download Calibration and XML files for this car. SPS updated BCM and IPC without any problem. When I use XML and Build files to configure BCM, DPS works ok, when I do the same to IPC, I always end up with "security access failed". Tried with Calibration files, made archives and I can write Calibrations to BCM no problem, but when I try to load Calibration archive for BCM, comm starts and I get security access error.
It can't be wrong XML file, as I downloaded XML directly for this car. With SPS it work fine, but when I select "no tpms" option in IPC programming I still have error in dash, so I need to remove it by DPS
Best guess is you didn't change it to pin 1 with DPS.. BCM is programmed using pins 6&14 and IPC is done with pin 1..
Thanks given by: Sweaty
(02-05-2025, 12:45 AM)Tek1229 Wrote: Best guess is you didn't change it to pin 1 with DPS.. BCM is programmed using pins 6&14 and IPC is done with pin 1..
Yep, That was it, thanks for the tip, it worked like a charm. Now I need to properly modify calibrations in BCM and IPC. Anyone can help with removing TMPS in BCM calibration files ?
Try config bcm again
Cadillac
05-26-2026, 04:33 AM
05-25-2026, 07:35 AM
