  • 139 Vote(s) - 2.95 Average
DTC off service Free, EGR DPF VSA OFF ! Menbers MhhAuto.
136
Can you check my egr off and delete P0400 from the DTC table
.zip
Ori+egroff.zip
29
533.19 KB
can you please do dpf off and all related dtc please
i have a peugeot 407 here with glow plug problems,stuck in limp and glow plugs siezed in head.can you turn of code p1351 and remove power limiter.
i have attached two files.one is original flash and second is the dpf off flash.
please note that i have no fault code with dpf off file and all is good but still in limp mode due to glow plug problem.
ecu 0281011633 bosch 1.6 hdi
thank you Sweating
If I helped please remember to hit[Image: 049.gif] Thanks + Rep
(09-11-2016, 09:46 PM)dpffiles.com Wrote: Please contact me skype
Just sent message.
thank you
Hi i need DTC off to a MED9.1 ecu file
I need dtc off for Tongue0219 ,P310B , P1297 & P2188
Thanks!
Hello ,
Can I have EGR Off for BMW 530D e60 2003 EDC16C31 - 1037390908?
Thank you for your time !
.zip
Factory Version.zip
22
168.27 KB
Is possible to disable dtc P0404 and P0403 On this visteon dcu land rover?
If not possible also all dtc table is ok for meHandshake
Thanks friend
Mod.rar
17
208.78 KB
Hello friend i need dpf off on nissan qashqai 2.0d bosch ecu 2009, faultcode is p1435
Can you please make DTC off : P1312 and P1334
It's a SAAB 9-5 2.0 TURBO 150HP.
Thank you!
saab.rar
25
167.4 KB
...extreme possibilites.
