Dodge 4500 unable to program key
Hello, just curious if anyone has any knowledge on the ram systems in regard to anti theft and programming keys. I am working on a 2013 ram 4500 Cummins that was missing many modules such as PCM, ignition switch, cluster and radio and am having trouble programming keys. It goes through all the steps but does not learn the key. I have fobik keys and the fobik ignition module but it doesn’t accept key programming.
I am using Autel im608 pro.
Well here is an update for those that have never programmed dodge keys before. New fobik keys need to be used; old keys that were programmed to a different car will not work, they need to be blank. Hopefully this helps someone out in the future.
05-04-2026, 11:57 PM
